spark plug wires..
Old Sep 30, 2009 | 05:25 PM
thecruzs2007@yahoo.com's Avatar
Default spark plug wires..
so i was wondering how do i know if i should change my spark plug wires? some symptoms? thanks
Old Sep 30, 2009 | 06:38 PM
Default Re: spark plug wires..
anyone?
Old Sep 30, 2009 | 06:51 PM
Linked's Avatar
idk how you can check wires other than the spark plug simply not firing.
Old Sep 30, 2009 | 07:18 PM
cause sometimes it doesnt wanna start up rite away...and my gas millage sucks..
Old Sep 30, 2009 | 07:30 PM
Linked's Avatar
when you rev it, or sometimes at idle. is smoke coming from your exhaust? if its blue or white one of those, i believe some fuel isnt getting burnt, so you might be misfiring, but you would get a CEL for that.
if your getting bad mpg, it just may be time for a full tune up anyways
acake em1's Avatar
Colonel Cake Mix
well are u always getting a spark? cause if u arent getting a spark it might be more than just ur wires/plugs
Old Sep 30, 2009 | 07:32 PM
clean92ex's Avatar
you can use a digital multimeter and check the resistance in the wire. just stick one lead from the meter to one end of the wire and the other lead to the other end. make sure your meter's on ohms. the reading should be rather low. you can get a cheap multimeter at most hardware stores
Old Sep 30, 2009 | 07:34 PM
no smoke..no CELs...it doesnt do it all the time..just 2 out f 10 times i would say..and it idles really low..like 700-800...
Old Sep 30, 2009 | 07:37 PM
acake em1's Avatar
Colonel Cake Mix
when it idles does it bog down like its not getting enough fuel?
Old Sep 30, 2009 | 09:08 PM
no like its at 1k then it goes down slowly and it just stays there..sometimes i think its going to shut off but it never does..
Old Sep 30, 2009 | 09:24 PM
egsleepercivic's Avatar
go outside when its dark and mist a little water on the wires start it up and see if you see any sparks they will be blue, I knew mine needed to be changed when I touched them while my car was running and got shocked...lol
Old Sep 30, 2009 | 09:27 PM
acake em1's Avatar
Colonel Cake Mix
have u adjusted your idle screw to fix the idle problem
Old Sep 30, 2009 | 09:29 PM
^^^ no i havent...i dont know where that screw is...and wat way should i turn it to make it idle higher? counter clock wise or clock wise?
Old Oct 7, 2009 | 09:47 PM
Si-r Potter's Avatar
New User
check the resistence in the wires, if is more than 25 ohms change thy
Old Oct 7, 2009 | 09:53 PM
acake em1's Avatar
Colonel Cake Mix
the idle screw is on your throttle body, turn your car on and turn the screw both ways and see which works, i cant remember off the top of my head which way.
Old Oct 8, 2009 | 08:47 AM
CivicSpoon's Avatar
^ Or run the car and listen to the idle. Then with the car still running, mist water on the wires and listen for an idle change. If there's a change in the idle, then the wires are bad.
thecruzs2007 - I wouldn't mess with the idle screw until you check for other problems first. If you play with the idle screw first, and then later on fix the real issue, your idle is going to be off from adjusting it.
Old Oct 8, 2009 | 08:59 AM
jdm_alex1996ex's Avatar
last time i check this isnt a carburetor civic the iacv will just re adjust it back into the same spot.. check your plugs they are the man-ly version of using your own dignostics. if they are saturated in gas your not sparking. how old are your wires
Old Oct 8, 2009 | 09:02 AM
scrambled_EG's Avatar
700-800..... isn't that what it's supposed to idle at or around it??
Old Oct 8, 2009 | 07:00 PM
almost 900
LordAphotic
Sep 22, 2010 12:04 PM
black cx
18
Nov 28, 2004 01:05 PM
jaycapz
May 9, 2004 10:55 PM
SiR Kid
Oct 10, 2002 07:49 AM
TDRacing
Jul 18, 2002 10:58 AM
