how to paint capiler?
Old Aug 28, 2002 | 02:24 PM
itr1244's Avatar
Default how to paint capiler?
i wanna paint my capiler cuz it's fading~
i just got a flat black paint but i dont know how i should paint it~
should i remove the capiler? if so how do i remove it?
any comment will help~ thx alot
Old Aug 28, 2002 | 02:26 PM
Bbasso's Avatar
Default Re: how to paint capiler? (itr1244)
leave it on and tape everything up...
sand down what you want and then clean it then spray
Old Aug 28, 2002 | 02:27 PM
uNF$@#!'s Avatar
Default Re: how to paint capiler? (Bbasso)
the easiest and less messy way would be to take off the caliper and mask everything off, and then sand and paint with hi temp engine enamel.
Old Aug 28, 2002 | 02:28 PM
itr1244's Avatar
sanding is required?
if so what kind of sand paper?
umm like what number?
Old Aug 28, 2002 | 02:34 PM
STC's Avatar
STC
Sanding is required to do before all paint jobs.
Old Aug 28, 2002 | 02:35 PM
Cosworth's Avatar
You don't need to sand it...
just remember to get high temp paint... anything over 750F should be availble at your local automotive store.
Old Aug 28, 2002 | 02:37 PM
itr1244's Avatar
this will do??
and how should i paint the center cap part? i have rota shitstream and i see rust there~ how can i remove rust and paint?
thank you
Old Aug 28, 2002 | 02:44 PM
uNF$@#!'s Avatar
Default Re: how to paint capiler? (Cosworth)
yep, no sanding necessary.
i didnt sand mine.
actually i did apply primer though.
either way i cleaned it off with brake cleaner first.
then applied all paint by paintbrush at a very painful rate.
NEVER AGAIN!
Old Aug 28, 2002 | 02:45 PM
Aussie_ITR-0239's Avatar
New User
There is NO long term messure for this; as you'll get stone chips etc and simply need to respray in about 6 mths!! Therefore, don't go 'overboard' with sanding & taping etc -
1. Remove wheels (obviously!).
2. Get an 'air gun' & clean everything with that.
3. Spray the caliper (while attached) with neat & tidy strokes.
DON'T worry about any small amount of 'over spray' on the brake disc (unless you're really silly!); as it will simply rub/burn off during driving.
Good luck....
Old Aug 28, 2002 | 02:47 PM
Ibuprofen's Avatar
does it matter if its high heat paint or regular?
Old Aug 28, 2002 | 02:51 PM
New User
Default Re: how to paint capiler? (01-0531)
Think of the temperatures involved in 'braking' and you realise that 'high heat' paint would be BEST!?
Old Aug 28, 2002 | 03:33 PM
kkim's Avatar
Default Re: how to paint capiler? (Aussie_ITR-0239)
don't know if that's good advice. brake dust can be very harmful if the pads contain asbestos. Helms manual cautions against using air to clean off brake parts.
Old Aug 28, 2002 | 03:47 PM
New User
Default Re: how to paint capiler? (kkim)
What then....is 'sanding' going to be any less dangerous?? Obviously if you know your 'pads' have a high asbestos content, then you may have to think twice?!
Eitherway - like with any 'spraying' etc....one should wear the appropriate 'safety' gear (ie mask in this instance)!
Old Aug 28, 2002 | 04:04 PM
GettaluvR's Avatar
New User
this will do??
thank you
u got the paint at canadian tires? that is **** @@
get some japanese stuff
Old Aug 28, 2002 | 04:06 PM
kkim's Avatar
any method that keeps the dust particles from getting airborn is preferred to keep from getting inhaled. wiping it down with a solvent soaked rag or even a dry rag is better.
most brake pads shouldn't contain asbestos, as far as I know, but you never know with some parts you buy.
Old Aug 28, 2002 | 04:12 PM
New User
Cool, I'm glad we agree on that....
I'm off to work now, given it is now 10:09am (on the East coast of Australia)....it's a good thing that I live/work in the Melbourne CBD and have <10 mins walk to work!! he he he
Old Aug 28, 2002 | 04:25 PM
kkim's Avatar
G'day, mate.
[Modified by kkim, 1:25 AM 8/29/2002]
Old Aug 28, 2002 | 06:56 PM
New User
G'day, mate.
'Hang Loose', man....right back @ you!
Old Aug 28, 2002 | 08:52 PM
mstewar's Avatar
if you want to paint that part, remove the wheel, tape off everything, sand the rust off, then give it a good spray.. i would assume it would work the same way as painting the caliper.. try not to get too crazy with overspray if you don't tape stuff off though..
Old Aug 29, 2002 | 12:49 AM
itr1244's Avatar
Default Re: how to paint capiler? (mstewar)
thx guys
Old Aug 29, 2002 | 04:26 AM
MiraiZ's Avatar
advice: don't use the spray crap...get the paint on type...
Old Aug 29, 2002 | 05:45 AM
Anderson's Avatar
Default Re: how to paint capiler? (MiraiZ)
good luck
Old Aug 29, 2002 | 05:58 AM
AssPenny's Avatar
Default Re: how to paint capiler? (Anderson)
Remove them, hold them off to the side with your hand or a wire and spray them down with some bbq spary paint... works like a charm. Just don't touch them when they are done because it will rub off untill its baked on by the heat of the brakes
It will still come off, the dealer that cleaned my car used a pressure cleaner and this happened. The red circles are something else (where I took a die grinder the them )
Old Aug 29, 2002 | 06:46 AM
Fugazi's Avatar
New User
Default Re: how to paint capiler? (AssPenny)
I haven't tried this myself, but this stuff seems to be what you want to use. G2 brake caliper paint. It has two different components that you mix together and then apply to your calipers. Kinda like JB weld. This stuff isn't supposed to ever come off. If you use it let me know how it goes.
http://www.seriousauto.com/hard-part...int-index4.htm
Old Aug 29, 2002 | 06:56 AM
Mai_CL-S's Avatar
New User
Default Re: how to paint capiler? (Fugazi)
i used a plastic grocery bag and wrapped everything but the caliper. Works like a charm
