lsVtec knock sensor issue obd2 p73
Old Sep 30, 2009 | 02:43 PM
superhatchbackbros's Avatar
Default lsVtec knock sensor issue obd2 p73
hey guys ij ust got done building my lsvtec and its in a 99 integra gs and im runing a obd2 p73 ecu!
know it goes off and comes back ETC! keep geting a damn code for knock code 23.
i have it screwed into the front of the tranny bc i dont ahve the front tranny mount on thier due to i ordered hasport 88a mounts! so i only have the 3 mounts!
i was told from a few friends that it will be fine and work! it does but once in a while the check engine light pops on!
can someone please help me figure something out! thanks in advanced honda-tech
Old Sep 30, 2009 | 07:59 PM
Default Re: lsVtec knock sensor issue obd2 p73
will this put my car in limpmode?
Old Sep 30, 2009 | 08:48 PM
ls_vtec_da's Avatar
if you convert your car to obd1 and chip it then you can take to any honda performance shop and they can disable the knock sensor and they can give you a base map for the ls vtec setup most shop chip the ecu for like 20 bucks.
Old Oct 1, 2009 | 09:31 AM
hey thanks for the response but i know all about that! i was just wondering a easy cheap fix for now till i bring the car down to obd1
Old Oct 4, 2009 | 08:26 AM
staying obd2 how can i delete the knock? its pissin me off and keeps jumping on and throwing a code! and my car seems to run slower lol is it true when it goes on the car cuts the power? but will still hit vtec?
superhatchbackbros
Nov 20, 2009 09:49 PM
colombian linx
Sep 4, 2004 06:44 PM
Jimmy L
Apr 17, 2003 10:58 AM
