All motor 81mm GSR pro2 carnage pics
I serve phở for my babies
Cylinder #2, where the valvestem broke
metal in cylinder #4, btw is that a keeper?
OS intake valves + pro2's = NO NO, i've learned my lesson guys..
Scars from metal debrees on cylinder #4
Lucky Chamber #2..
It started when i missed a power shift from 1st-2nd, did a few more runs, pulled over and i noticed the car was smoking.. didn't know from what, i figured it bent a valve. on the way home i went into vtec and motor quit.. lost all compression
and 9 months later i finally pulled the head off..
before i pull the motor out (which it will probably be never) do you guys think my bottom end is good? (crank, rods, oil pump, etc) I know for sure i'll need new pistons if the motor is rebuild able.. what do you guys think?
Lucky Chamber #2..
actually, that "keeper" looking thing is from my valve guide now that i think of it. all the keepers are still intact..
i think i bent a valve on the misshift, then on the way home i went through the powerband and that's what broke the valve which sent all the crap into my intake manifold and all the metal that went into it poured into my other cylinders.
ok, motors blow, we learn the hard way on some things but...
wtf
also, what valves are they? i've never seen a honda valve head come off.
wtf
rev limiter was set at 9k, i'm sure the supertech valvetrain wasn't the blame, these are ferrea valves with 1mm os intake valves. the extra 1mm was a $2-$3k mistake
the block should be salvageable. i'm not positive about the head, but maybe you'll be able to get a port and polish to clean up the head?
Sorry about your lost Bro... That sucks but looks like you dropped that valve.... I would think that your bottom end is salvageable but it wouldn't hurt have it inspected for any damages... From the picture of chamber 2, its looks repairable... I would consult cccylinder heads...
well a guy from this local shop made me a deal on the ferrea valves for $100 bucks that i couldn't pass up, he somehow stooped me into buying them.. at the time i didn't know what cams to run so i purchased them. got the head machined.. etc.
and i read up on pro2's with os valves and many just said make sure all clearances are fine. so i had a local shop degree the motor.. which obviously they didn't do
I know....its always the shops fault. And anyways doesn't skunk2 recommend to not use oversized valves? There are so many variables that i dont think you can blame the builder.
Degreeing in cams does not tell you your clearances.
If the machine shop had measured P2V and V2V, this would not have happened.
And you CAN use OS valves with Pro-series cams, you just need to measure V2V and compensate by advancing the exhaust cam even more (in the +5 to +7 range).
Damn, i remember a few months ago you were putting this motor together.. ..had some good hopes for this motor.. sorry again dude.. :-\
you learn tho.. If you aren't 100% trusting run what you know will work.. which isn't OS valves.
at the time i didn't know what cams i wanted to use. that's why i couldn't research yet. when i found out i wanted to use pro2's many people said you can run pro2's with os valves, you just have to check and compensate all the clearances like 92typer stated
my tuner was the person who degreed the cams, they said they clayed the motor and all the specs were fine. i specifically told him i had OS valves, and skunk2 did not recommend that....
all in all, one thing led to another which led to my catastrophic failure
After waking up, drinking more coffee, and re-reading your first post, it sounds like the missed 1-2 shift caused the valve to float, causing contact with the piston resulting in a bent valve. Once the valve was bent, it was only a matter of time before the valve dropped completely.
If you had V2V clearance issues, you would have encountered disaster upon first trip into VTEC. What were your camgear settings prior to the failure? I can guestimate based on that whether you were going to touch valves.
