Timing belt loose with pics..WTD?
Old Sep 30, 2009 | 01:03 PM
mynumer1hater's Avatar
Default Timing belt loose with pics..WTD?
Timing Help with pics
1. What piston should I put the motor on for TDC?
2. Do the cam gears look lined up right?
3. Why does the crank pulley marks not line up with the timing pointer on the timing cover? Also there are 3 marks on the crank pulley. What mark should line up with the timing pointer on the timing cover?
4. I know the tensioner is loose or broken so there is a lot of timing belt slop and it is making a lot of noise.
5. Compression test done 250psi plus, on all 4 cylinders.
6. If the cam gears are lined up why is the crank not lined up with the timing cover?
7. The set up:
8. B18c1 bottom end
GSR crank and rods
CTR .25 over pistons (PCT)
ARP head studs
ITR water pump
B16A oil pump
NEW tensioner
DC sports 4-1 header
HEAD:
B16A head, ported and polished, 5 angle valve job
ITR cams
ITR valve springs and retainers
ITR injectors
B16 intake
Old Sep 30, 2009 | 02:02 PM
postman's Avatar
Default Re: Timing belt loose with pics..WTD?
i believe ur using the wrong tdc mark on the crank pulley. when setting tdc the pointer on the crank is all by itself. not the middle 1 in the group of 3.
the 3 marks in a row are used to set timing advance and retard on the distributor
when on that mark the slashs on the cam gears should point at each other and be inline with the mark on the rear cover. there should be marks on the outside edges of the cam gears also to, that lineup with the outside edges of the top of the head. use something flat to verify in line on outside edge.
Old Sep 30, 2009 | 05:26 PM
EcRzFinesT's Avatar
piston 1...cylinder 1 is the one away from the tranny side
Old Sep 30, 2009 | 06:37 PM
the one closest to the cam gears...right?
Old Sep 30, 2009 | 06:39 PM
EcRzFinesT's Avatar
yup...near all the pulleys
my timing belt maybe off also...my pick up is crazy slow....im prob gonna be taking the timing belt off this weekend...let me kno how ur mission goes.
Old Sep 30, 2009 | 06:51 PM
I will post up pics..
Old Sep 30, 2009 | 09:07 PM
em1pusha99's Avatar
what you could also do to check yourself while the valve cover is off is, put the crank at TDC and feel your rocker arms both intake and exhaust on cylinder number one, if there is play and the cam gears line up right your timed right. idk just an idea.
Old Oct 1, 2009 | 07:10 AM
mouab18c1's Avatar
for my cam gears i usually just line up the UP arrows instead of the markings on the side of the cam gears....
Old Oct 1, 2009 | 11:36 AM
PM sent>>>
Old Oct 1, 2009 | 06:14 PM
I will try and get it done this weekend, and drive it monday. If you guys think of anything else LMK..
pic of the car:
Old Oct 1, 2009 | 06:38 PM
projectTeG's Avatar
your bottom end isnt lined up(at tdc cylinder one and four will be a the top of the cylinder. tdc on the head is the lobes facing in opposite directions front and back). also it looks like you not tensioning the belt properly. you have to tighten the tensioner, at tdc, then rotate the engine 3 teeth counterclockwise, then loosen and retighten the tension to 35ftlbs.
Old Oct 5, 2009 | 12:43 PM
I GOT IT!!! It took a couple of tries but its done. Thanks for the help and encouragement .
alex14
12
Sep 29, 2010 01:01 AM
mynumer1hater
Sep 22, 2009 06:21 PM
jdmthug
Aug 22, 2009 07:09 AM
Concept Tuning
Jun 29, 2006 06:33 PM
deSigi
May 15, 2005 06:46 PM
