problems with my dohc zc
Old Sep 30, 2009 | 11:02 AM
caseyman4285's Avatar
Default problems with my dohc zc
k so my car only revs out to 3200 rpm like a 2 step. i was told it was my distributor so i took it of and spun the shaft and it doesnt move smooth at all it spins but it feels like its catching on something every time it move a tooth on the inside idk if thats normal or what but it doesnt seem like it. thanks for the help.
Old Sep 30, 2009 | 11:45 AM
Default Re: problems with my dohc zc
Old Sep 30, 2009 | 11:47 AM
dephtone's Avatar
Yes the distributor is supposed to feel like that.
Are you throwing any codes? Check your MAP sensor to ensure it is plugged in correctly with the corresponding vacuum line going to it.
Make sure the plug that is plugged in has a yel/red white and green/white colors coming from it. If not, you might have switched up the TPS and the MAP sensor plug, which is a common problem.
Old Sep 30, 2009 | 02:01 PM
crxjarred's Avatar
i just did a dohc zc swap and im finishing it up now runs like a champ heres what i followed http://www.zcspeed.com/HFZCwiring.pdf
Old Sep 30, 2009 | 02:08 PM
.Manny.'s Avatar
Touching My Member
double check all of your connections, don't assume everything is correct. your ECU is in "limp mode" for a reason
acadiasparta
Mar 15, 2013 02:58 PM
91bluehatch
Jan 25, 2005 08:22 PM
SiRWannabe
Aug 9, 2003 09:12 AM
FourthGenHatch
Jun 19, 2003 01:54 PM
polycrx
Apr 11, 2003 09:08 AM
