need help wiring dizzy. Stuck in middle of swap.
Old Sep 29, 2009 | 09:01 PM
jdmeg21's Avatar
Default need help wiring dizzy. Stuck in middle of swap.
Hey guys, i'm doin a swap for my buddy, he dropped off the motor, so I pulled his old non vtec sohc motor out. pulled the old tranny and swapped onto new motor. Now he dropped off I dizzy, but the 2 connectors are different then whats on the wiring harnesss. How do I take care of this mess. can I cut the connectors off the old one and put on the new dizzy. the colors of the wires seem to be the same on the 2 dizzys just different plugs.
harness is stock 90 crx, non vtec, old dizzy from this motor
new dizzy is from 94 civic si. for vtec motor.
need help guys want to get this done asap. I need the garage space.
Old Sep 29, 2009 | 09:03 PM
YourLocalJerk's Avatar
Default Re: need help wiring dizzy. Stuck in middle of swap.
what kind of vtec motor are you putting in??
Old Sep 29, 2009 | 09:22 PM
jdmeg21's Avatar
block says zc, dizzy had 94 civic on writen on it. IM had 94 civic vtec writen on it.
Old Sep 30, 2009 | 06:20 AM
jdmeg21's Avatar
help bump
Old Sep 30, 2009 | 06:32 AM
jlicrx's Avatar
to use the OBD1 distributor, you will need to use the OBD1 ECU which means converting from OBD0 to OBD1 with ECU jumper harness - if his car was DPFI, you will need to convert the wiring to MPFI
Old Sep 30, 2009 | 11:22 AM
D16SiHatch's Avatar
like jlicrx said, you will need to convert from dpfi to mpfi if the car is not an Si or Hf
http://hondaswap.com/swap-articles/d...writeup-49557/
to use the dizzy you'll need an obd0-1 adapter harness.
you can make one..
http://www.d-series.org/forums/diy-f...-adapters.html
or buy one from various places, here's one.
http://www.jhpusa.com/store/pc/viewP...idproduct=4200
kylesmith3251
13
Jan 16, 2009 08:17 PM
SurfKid3
Apr 7, 2006 11:43 AM
cjwarren4dcivic
Feb 26, 2006 12:32 PM
b18racer420
Apr 7, 2004 08:59 PM
