Transmission & Drivetrain Gearboxes, Differentials, Clutches
tranny case ring
Old Sep 29, 2009 | 08:25 PM
russlan44's Avatar
Default tranny case ring
whats the worst could happen, almost done with my h22 swap into civic and was about to add tranny oil when i saw the snap ring wasnt in all the way. i took the tranny apart to see hows things are in there and when i was putting it back the snap ring on bearing didnt snap and i didnt payed attention cuz i was in hurry. tranny case sit but ring only went it on one side and bearing is pushing the other side of the ring that didnt go in and i can move ring anywhere
whats the worst could happen if i drive?
or tips on putting the ring back into place without taking the tranny apart.?
if anyone doesnt know whats a snap ring heres a pic i took from google, whos ever this pic is tx
Old Sep 29, 2009 | 08:36 PM
Aquafina's Avatar
Default Re: tranny case ring
Break the top CSB, break the case, damage gears and bearings if neither of the first happen.
Old Sep 29, 2009 | 08:55 PM
russlan44's Avatar
so if the snap ring doesnt line up tranny will get F*ed if i start driving
Old Oct 1, 2009 | 03:32 AM
Mista Bone's Avatar
D Tranny Guru
If you tighten the case down without spreading the snap ring, you;ve alreay broke the outer race or the case.
If you did spread the snap ring when installing the outer case, use FORD to get the countershaft to lock into the snap ring.
Flip Over, Read Directions
Old Oct 1, 2009 | 06:41 AM
Aquafina's Avatar
lol, that was cheesy.
Old Oct 1, 2009 | 07:24 PM
Mista Bone's Avatar
D Tranny Guru
Lack of sleep does that
Old Oct 1, 2009 | 08:26 PM
Honda Bull's Avatar
Did you spread the snap ring or not before tightening it down?
And how did you notice it when about to fill it with oil? The cover over it should have been put on before you fill with oil and start the engine... For the sake of your wallet and your trans, please don't do things ***-backwards. lol
Old Oct 2, 2009 | 09:37 AM
russlan44's Avatar
i didnt spread the ring, when i was rebuilding my d series tranny the ring snapped on really easy and now that i was doing my h22 swap and wanted to get it done and lack of sleep and just being busy i totally forgot about it. everything is tight down, im taking the tranny off on sat hopefully
Old Oct 2, 2009 | 06:05 PM
Mista Bone's Avatar
D Tranny Guru
might have broken alot of things.......
Old Oct 3, 2009 | 08:08 PM
JDM Lyfestyle's Avatar
similar problem ..I had to change the shifter assembly on my itr tranny and when reassembling I couldnt get the ring to snap in for anything. it was spread when i tightened down the case.. but wtf do I do to get it to snap in now??
Old Oct 3, 2009 | 09:12 PM
russlan44's Avatar
How if I haven't even drove the car yet
Old Oct 4, 2009 | 10:45 AM
Mista Bone's Avatar
D Tranny Guru
FORD: Flip Over.......gravity is your friend
Doesn't matter. You likely broke the the bearing and maybe damaged the case.
Old Oct 4, 2009 | 12:20 PM
Tried that... didnt work a ****.. tried dropping it on a piece of wood ..all kinda tings
Old Oct 5, 2009 | 01:58 AM
extralargenog's Avatar
yhe fail is strong... You ned to spread it out first then atomic drop that ****....
Old Oct 5, 2009 | 10:14 PM
russlan44's Avatar
took the tranny apart and heres the damage, what u guys think?
couldnt get the camera to focus
Old Oct 6, 2009 | 01:19 AM
Mista Bone's Avatar
D Tranny Guru
what ever gunk is in that bearing needs removed.......
Alignment tab for reverse synchro looks damaged, but hard to tell in the pics.
You also used the wrong sealant for the case and used 3x too much.
Strip it all back down, do it again.
Oh yeah, get a workbench and some 2x4's so your not resting on the mainshaft.
Old Oct 6, 2009 | 10:10 AM
srsly wtf is with peanut buttewr jelly time in thast bearing. Your dsnap ring looks suspect too, but i cant tell because of your pic quality.....
Like bone said. Go get yourself a tube of ultra grey (or honda bond if youre balllllin)...either way you dont need so much that it displaces all over the place when the case is tight... BUt fdo take some time and make sure that the mating surfaces are clean as you can get em... At least I do, and I (as Bone) Build alot of trannys. H trannys.
BTW LOL at the tags for this thread that appear at the bottom of the page hahahhhaha
Tags
***, ladyboy, pic, *******, tranny
-tc-
Oct 25, 2005 07:44 AM
NitrousB.I.G.
Jul 16, 2004 05:00 AM
ultimatehonda
Apr 30, 2004 08:03 AM
Tyson
Apr 22, 2004 06:20 PM
B18C5-EH2
Nov 13, 2001 01:59 PM
