First gear doesnt engage GSR
Old Sep 29, 2009 | 06:25 PM
mugen727's Avatar
Icon3 First gear doesnt engage GSR
Hey I'm new to the game and have a 2000 gsr. Previous owner installed a short shifter. One con to the car right now is that once in a while it does not fully engage into 1st gear, it would go only half way. I would have to go back to neutral, step off and on clutch again and shift to 1st. He told me to bleed the clutch line and should be fixed. My other friend told me its because of the short shifter and he has that problem too. Anyone else had this happened to them? and how did you fix it?
Old Sep 29, 2009 | 07:13 PM
vladd's Avatar
Default Re: First gear doesnt engage GSR
i'd start with putting the stock shifter back in and see what happens.
Old Sep 29, 2009 | 07:33 PM
nonsense's Avatar
Bleeding the clutch line could help. It's easy to do and will probably take less time than switching out the shifter if you have a helper. I found that a 2nd-3rd gear grind practically disappeared when I bled my clutch (went from grinding at 4000 rpm to only grinding above 7500)
Old Sep 30, 2009 | 09:16 AM
teamjdm239's Avatar
cld be the shifter.. what brand is it ? it could be that its faulty ( wasnt bent right)
Spinks
Honda Civic (2006 - 2015)
Nov 23, 2010 06:01 PM
joshalee
Mar 25, 2004 05:10 PM
ronman92
Apr 17, 2003 08:26 PM
blackhatch13
Mar 28, 2003 03:20 PM
