is my iacv gone??
Old Sep 29, 2009 | 06:15 PM
itzyaboyzeem03's Avatar
Default is my iacv gone??
well my car has been idling at 1100-1200 rpms lately...so i unplugged the iacv to try and adjust the idle a lil bit, and when i unplugged it my car dropped and was bearly staying on...it went from 1100 to like 200 rpm....does that mean i should just change out my iacv?? because i though its only suppose to drop about 100 rpms when u unplug it
Old Sep 30, 2009 | 01:20 PM
Default Re: is my iacv gone??
anyone>>????
Old Sep 30, 2009 | 01:28 PM
ferio252's Avatar
Well you're rpms ARE supposed to drop when you unplug the iac. Possibly there is carbon buildup in your iac. Can you reach the idle adjust on the throttle body without removing iac?
Old Sep 30, 2009 | 03:49 PM
u mean the idle adjusting screw?? yes i can....
Old Sep 30, 2009 | 04:11 PM
goldfinger93030's Avatar
no just clean the iacv and then after you put it on you should be able to adjust your idle screw if it doesnt drop significantly the tension on the throttle cable might be too much
Arthas
Mar 14, 2010 09:08 PM
90Rexx
Jul 2, 2008 08:53 AM
sik_sol
Aug 18, 2006 02:08 PM
oi-punx
Nov 14, 2002 02:01 PM
