INFO NEEDED: Rear speed sensor kit
Old Sep 29, 2009 | 05:37 PM
base-op.1320's Avatar
Default INFO NEEDED: Rear speed sensor kit
I was told there is a kit for a rear speed sensor that people use for boost by gear and what not. I am wanting to shift on mph instead of rpm so when it spins in first I can nail my shift perfectly everytime without shifting early or late. any info is greatly appreciated.
Old Sep 29, 2009 | 05:50 PM
swapit's Avatar
Default Re: INFO NEEDED: Rear speed sensor kit
You use the rear factory abs sensor,
Old Sep 29, 2009 | 06:05 PM
boostek9's Avatar
what if you dont have abs, do you have to swap out rear brake set-up? i am running a DX hatch with rear drums? thanks for info
Old Sep 29, 2009 | 06:30 PM
swapit's Avatar
just need the abs ring to go onto the hub and the sensor or go to the junkyard and get a rear disc set-up with all the stuff on it already.
Old Sep 29, 2009 | 07:16 PM
Thanks for the reply - So if I have abs then its as simple as just wiring the abs sensor to the ecu where the vss origanally was installed?
Old Sep 29, 2009 | 07:18 PM
I already have read where someone was running rear vehicle speed sensor on drums, because they installed a spool without the vss gear on it. Maybe it can be purchased from the spool company or they might have some input.
Old Sep 30, 2009 | 05:22 AM
96 GSR-T's Avatar
In for more info on this, I always wondered how VSS Boost worked if you were spinning. How do you wire in the sensor (0-5v sensor I am assuming?)
Old Sep 30, 2009 | 09:39 AM
You could still run boost by gear off your trans vss you would just have to make sure that the mph set is higher than your max speed when spinning at redline. It would take some datalogging and time to set it up, but still wouldn't work as flawless as rear tire plus you could bring in power anywhere you want. I would also like to datalog both vss's and clearly see where the tires are breaking loose when setting up boost by gear.
Old Sep 30, 2009 | 11:39 AM
tepid1's Avatar
What EMS are you using?
I've got mine set up with a Motec hall sensor on the right rear.
Old Sep 30, 2009 | 02:32 PM
I am just wanting to be able to do it on crome and hondata, mostly want the speedo in the cluster to read rear mph.
Old Sep 30, 2009 | 05:22 PM
boostek9's Avatar
base-op is my tuner, so someone help us get this done
up up
Old Sep 30, 2009 | 06:29 PM
locash's Avatar
Good luck on that one.. Crome has boost by gear?
Old Sep 30, 2009 | 06:53 PM
I wasn't wanting to use crome for boost by gear, I was wanting to read out on the dash cluster my rear tire mph to make my shifts dead on with mph instead of blowing the tires off and just guessing the right time to shift or waiting for the car to fall on it's face. But we are setting up a hondata for boost by gear either way off of tranny vss or rear vss doesn't really matter.
641iowaguy641
Jul 22, 2013 09:58 AM
johnjk
Honda CR-V & Element
Aug 7, 2012 03:59 AM
IVIcGurk
Apr 17, 2006 10:41 PM
RealFlyinghorse
Sep 7, 2004 11:27 AM
