intake manifold gaskets help!!
Old Sep 29, 2009 | 04:30 PM
falcon548's Avatar
Default intake manifold gaskets help!!
hey im in desperate need of an intake manifold gasket, but only the one that is between the butterflys and the top part of the manifold. i cant seem to find this gasket or a full gasket kit...heres a pic of where i need it to be- the gasket should have 4 circles and 4 squares...i can only find TB gaskets and head-to-runner gaskets
Old Sep 29, 2009 | 04:55 PM
falcon548's Avatar
Default Re: intake manifold gaskets help!!
nevermind. solution found
http://www.blacktraxstore.com/index....k=1&Itemid=102
Old Oct 7, 2009 | 01:44 PM
falcon548's Avatar
bumpp the "solution" didnt fit on the ****ing studs. just lost my ****ing keys someone tell me where i can find this gasket
Old Oct 7, 2009 | 02:31 PM
313hitman's Avatar
MS94781 at autozone 11 bucks
Old Oct 7, 2009 | 05:14 PM
oranginal's Avatar
why didn't the part you listed fit?
what about just using hondabond?
Old Oct 8, 2009 | 12:48 PM
BlacktraxGirl's Avatar
Hi Ellen,
I noticed you have one of our manifolds, so ive emailed you about it with some more questions so that I can make sure youve got what you need for it to work with your set up, please let me know the info!
If you are looking for the middle section then it does fit, your emails were explaining things slightly different, if you want to stack our space ON TOP of yours then you will need our extended bolt kit which we make especially for double staking.
if you are looking for the "gasket" then yes autozone or hondabond as i explained to you in the emails.
Please be a little more specific with pictures or emails so i can make sure you get what you want and need, instead of ordering and then returning and then from the sounds of it having to order again.
Natalie
Old Oct 8, 2009 | 02:36 PM
jlude90's Avatar
Blacktrax with the customer service. Awesome.
Old Oct 8, 2009 | 06:40 PM
Hawkze_2.3's Avatar
The 'solution' is clearly listed as thicker than a normal gasket and requires extended studs
Rick1t
Feb 9, 2015 05:44 PM
actionfigure
11
Jan 3, 2007 08:25 PM
98HB
Mar 24, 2004 01:28 PM
dualknuttz1
Jan 23, 2004 08:37 PM
