Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What other transmissions fit the k20z3??
Old Sep 29, 2009 | 01:52 PM
aeenox's Avatar
Default What other transmissions fit the k20z3??
What other trannys fit the k20z3??
Old Sep 29, 2009 | 03:19 PM
Kidnkorner's Avatar
Default Re: What other transmissions fit the k20z3??
For what purpose and why would you want another transmission?
Old Sep 29, 2009 | 03:41 PM
haby red fg2's Avatar
i can think of atleast 2 reason's
2nd and 3rd gear would be mine
or the fact that honda wont admit there are many issue's with the tranny and fix the issues with out making you jump threw hoops
Old Sep 29, 2009 | 03:59 PM
i-VTEC_DOHC's Avatar
anything below 05 i think wont fit because of the different tranny housings.
Old Sep 29, 2009 | 04:52 PM
Kidnkorner's Avatar
Then you don't know a whole lot about K series transmissions because the cases from other/older K series transmissions aren't a direct plug and play set up and even then the gears aren't trouble free in other/older K series transmissions.
Your only option, if you can't get warranty work is going with aftermarket gear sets or replacing with OEM units. Both VERY expensive. There is no cheap fix when it comes to transmission work.
Old Sep 29, 2009 | 05:22 PM
K5^'s Avatar
K5^
Brand New
My vote is to replace internals.
Hey haby_red_fg2: how'd you change your user name from dys3767?
Old Sep 29, 2009 | 06:50 PM
vladd's Avatar
x2 on other k trannys have issues; the rsx-s is well known for having problems with 2nd and 3rd gear, just like our trannys are. aren't all the k20 trannys interchangeable though? other than the vss being different throughout the years.
mods can change it, i've seen it happen before too.
Old Oct 1, 2009 | 05:52 PM
in the user cp section i did that like 4 years ago so i dont honestly remember step by step
Old Oct 1, 2009 | 06:07 PM
vladd's Avatar
they don't let you do it yourself anymore; they used to, until the scammers started abusing the feature.
Old Oct 4, 2009 | 05:37 AM
like i said i did it a while ago and i dont really post a whole lot on this site as you can tell by how long ive been a member and how few posts i have
Old Oct 4, 2009 | 12:44 PM
vladd's Avatar
oh yeah?
SPIKE'S91CIVICSI
Mar 10, 2009 10:45 PM
baddog
Nov 18, 2004 07:07 PM
weetrk
Aug 16, 2004 09:36 AM
accordinglyevil
Jul 28, 2004 05:21 AM
