D16Z6 VTEC disabled I need help ... PLEASE??
So I bought this eg hatch it has a D16Z6 (motor swap)
However it has a P05 ECU more then likely stock ecu....
I didn't notice at first the but the Vtec Wiring is not connected.
So I have 2 Wires connectors chilling ...
So I asked the Seller if she had another ECU . She gives me a P2T ECU, I believe its an SI 99- 20XX ecu...
Im pretty much lost... If someone could explain to me whats going on here. Im thinking I could either wire something up with what I got or I might have to buy a P28 ECU.
Thanks in advance!!!!
that p05 ecu is for a cx motor. i know that a p06 can be modified to run as a p28, but i'm not sure about the p05... when you say you have "2 wires chillin", do you mean that you have 2 extra wires? i guess what i'm asking is do you have a vtec solenoid?
