90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched I installed a ODB1 B16A SiR
Old Sep 29, 2009 | 12:10 PM
EF7's Avatar
EF7
Default 90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched I installed a ODB1 B16A SiR
I installed a ODB1 B16A SiR II engine from a 92 EG6 into my 90 Civic Hatchback Auto.
When I fist started it, the idle was a 3,500 RPM, I cleaned the IACV and FITV and it didn't fix the issue.
Checked ECU for codes and I got 5 and 7. Fixed the vacuum routing to the MAP sensor and it helped a bit, then adjusted TPS to 0.45 closed and 4.5 wot.
ECU codes went away but now it idles at 2,000 RPM
When I cover the upper hole inside the throttle body (IACV hole) idle normalizes,
1. Is it possible for the IACV to be bad without throwing an error code on the ECU?
2. Where can I get a replacement IACV for this motor?
IACV from ODB2 B16's and B18's are different, will the IACV from a delSol Vtec work?
Thanks in advanced for any help.
Old Sep 29, 2009 | 04:13 PM
dannysolis92005's Avatar
Default Re: 90 Civic B16A SiR II ODB1 IACV/Idle Question - Searched I installed a ODB1 B16A S
i got the same problem. but i have that engine on a crx. 1. make sure that the vacum lines are connected right. i had the same problem if i covered a hole on one of the sensors it would calm the idle. so make sure they are right. 2. warm up the car till fan goes on, then turn off car. then disconect the MAP sensor. turn the car on and it will idle high now there is a screw on the throtle body by the vacum hose outlets. you have to turn that screw so that your RPM fall just a bit over/under 1k. 3. turn car off and disconnect the battery for a few seconds. make sure vacum hoses are right!
Old Sep 29, 2009 | 06:13 PM
EF7's Avatar
EF7
Do you have a diagram for the hoses on your car?
I've found a few different diagrams online, according to one of then the vacuum hoses are connected correctly.
Thanks
Old Sep 30, 2009 | 12:41 PM
no, they would be different though. just switch them up its all about trial and error.
Old Sep 30, 2009 | 01:53 PM
EF7's Avatar
EF7
Im almost 100% sure that my vacuum hoses are pluged in correctly. I just picked up a IACV from a 94 delSol VTEC B16A3
Hopefully this fixes the problem
Old Sep 30, 2009 | 04:40 PM
Crx Jimmy's Avatar
if it doesnt fix it, it sounds like you have a tb gasket leak. make sure to use a gasket from a b16 del sol.
Old Sep 30, 2009 | 06:53 PM
EF7's Avatar
EF7
TB gasket is new and its for a delSol VTEC
running out of options
Ryan Crisostomo
May 13, 2013 12:23 AM
EF7
Sep 30, 2009 07:51 AM
pompom
May 10, 2007 11:07 AM
trvrx_na
Jul 12, 2004 01:14 PM
6thgen4u2nv
Oct 11, 2003 08:06 AM
