can i use 89 octane on my gsr?
Old Sep 29, 2009 | 11:38 AM
95twotoneteg's Avatar
Default can i use 89 octane on my gsr?
i jus wanted to know if it will be safe to us 89 octane in my gsr?its on a stock ecu and not on much mods i jus need 89 for commuting pls help me out
Old Sep 29, 2009 | 12:17 PM
keepinitrehaal's Avatar
Default Re: can i use 89 octane on my gsr?
No
Old Sep 29, 2009 | 12:21 PM
racebum's Avatar
yes provided the car isn't ran under load or on a really hot day with ignition timing at 18btdc. in the heat or with more ignition timing you will get knocking. freeway driving? no big deal. still when you add up the cost of 91 at only a dime more a gallon that's roughly one dollar per fill up.
Old Sep 29, 2009 | 12:22 PM
TypeRMOBBiN209's Avatar
your not suppose to...but my friend use to use 87 in his gsr and it ran coo...but that car was a pos
Old Sep 29, 2009 | 12:33 PM
ALLxMOTOR EG's Avatar
Vietnamese!
This has been covered before.
The bottom line is that it will not hurt a stock vehicle.
The caveate is that 89 octane will result in lower fuel economy, which means that you don't actually save money.
It is in your best interest to run 91 like the manual says.
Old Sep 29, 2009 | 01:11 PM
Zappythebum's Avatar
^ ditto.
and you dont get all that awesome bleach that you get in the 91..
Old Sep 29, 2009 | 01:53 PM
Brice.Hayden's Avatar
91 whats that? i use 93 octane
Old Sep 29, 2009 | 02:30 PM
thats koo we dont have 93 or i would use it
Old Sep 30, 2009 | 09:22 AM
teamjdm239's Avatar
i use 93 too.
Old Sep 30, 2009 | 10:00 AM
hamizle's Avatar
93? i use e85
Old Sep 30, 2009 | 11:11 AM
racebum's Avatar
Originally Posted by hamizle
93? i use e85
hope it's boosted or running 12:1 +
e85 has less bang ounce for ounce than regular gas, it's higher octane is wonderful if you tune for it, you just consume more & need a map that supports it
Old Sep 30, 2009 | 01:34 PM
JL 74's Avatar
Are you doing this in attempt to save money?
Old Sep 30, 2009 | 09:17 PM
hamizle's Avatar
boosted indeed does wonders for numbers on dyno especially with torque. its pretty much race gas and over here its a dollar cheaper then regular
Old Sep 30, 2009 | 10:03 PM
racebum's Avatar
is and isn't ethanol has great octane numbers but requires more of it versus petro fuel to create the same thermal energy. this is why you will make less power on e85 if you dump it in something like a stock GSR. now if that gsr has 12:1 pistons and you tune it for e85 and it's higher octane, oh hell yea, you can run WAY more timing thus kicking the snot out of regular gas.
95DC2GS-R's Avatar
93 unleaded premium > all
Old Sep 30, 2009 | 10:06 PM
TonyRomo's Avatar
I only use 93. It is extremely hard to find 91 in NY.
Old Oct 1, 2009 | 09:33 AM
kulo's Avatar
u will get crappy mpg the low octane u go
im using bp ultimate 97 octane in my gsr
im getting about 34mpg
Old Oct 1, 2009 | 09:37 AM
Fortitude's Avatar
Old Oct 1, 2009 | 12:18 PM
vladd's Avatar
if you can't afford the proper gas then you can't afford the car. sell it and buy a sohc civic.
Old Oct 2, 2009 | 02:44 PM
NoeDC2's Avatar
New User
it says premium unleaded on the cluster.
Old Oct 2, 2009 | 05:05 PM
TunerN00b's Avatar
Which is 89 octane.
87 is low grade, 89 is premium, 91 is supreme.
Also keep in mind that different place rate the same octane differently. RON, MON, and AKI can be used for an octane rating, and do not match each other (in terms of the number listed).
That said, my GSR only gets 91. I've actually set off the knock sensor with 91 on a 105* day, and had to add half a tank of 105 to prevent it from happening the rest of the day. This was on track though, and running for 45 minutes above 6k RPM isn't exactly kind on the engine.
Old Oct 2, 2009 | 06:45 PM
Dogginator's Avatar
Daisy... Daisy...
Originally Posted by TunerN00b
Which is 89 octane.
In most locations, premium is 91 octane and midgrade is 89.
Old Oct 3, 2009 | 06:52 AM
kulo's Avatar
95 octance in uk is like 91 in the states
Old Oct 3, 2009 | 07:00 AM
Dogginator's Avatar
Daisy... Daisy...
Greetings, UK.
I think Japan has RON 100 for premium. I was talking about US octane before.
Old Oct 3, 2009 | 03:13 PM
KILLAB17VTEC's Avatar
Genetically Gay
i tested regular unleaded vs 91 premuim the differents are vtec kick-in harder and faster with the premuim gas.
