Code 15 after wiring vtec
Old Sep 29, 2009 | 10:30 AM
xXCarfreakXx's Avatar
Default Code 15 after wiring vtec
Okay so I got done swapping the gf's hatch got it running without vtec wired up (94 dx) ran good for a day then last night I pulled it in my garage to wire up vtec. I got all finished and went to start it and nothing. got a code 15. I looked over my wiring to see if i possibly messed anything up but everything looks good. Do you think its possible for the ignitor or dizzy to just go bad like that without any warning signs?
Old Sep 29, 2009 | 12:35 PM
Default Re: Code 15 after wiring vtec
Okay i replaced the coil and ignitor with known working ones and im still getting code 15... WTF is wrong.
Old Sep 29, 2009 | 12:46 PM
Former User's Avatar
Do you measure battery voltage at the Blk/Yel wire attached to the coil and igniter unit in the distributor?
Do you measure ~10V at ECU connector terminals A21 and A22 for the Yel/Grn wire attached to the igniter unit?
Hyunbs
Oct 25, 2013 01:40 PM
lvlistchif
Sep 25, 2009 02:43 PM
stealth civic
Jan 14, 2005 11:48 AM
trexb16
Feb 19, 2004 09:08 AM
