What happens when your dif starts to go bad?
Old Aug 28, 2002 | 12:42 PM
Chairman Kaga's Avatar
Default What happens when your dif starts to go bad?
What's the list of symptoms for a bad dif?
Old Aug 28, 2002 | 05:48 PM
Default Re: What happens when your dif starts to go bad? (chairmankaga)
Anybody? Grinding while accelerating with the wheel turned? Slight loss of power when turning? Noises? Anything?
Old Aug 28, 2002 | 06:15 PM
BreakStuff's Avatar
New User
FWD or RWD?
Tranny leak cuz you'll be knocking out the axle seals with a bad differential..
Old Aug 28, 2002 | 06:59 PM
rice a rona's Avatar
Default Re: What happens when your dif starts to go bad? (BreakStuff)
its either good or bad....youll know if it went out because the car wont go.
Old Aug 28, 2002 | 07:52 PM
FitCRX's Avatar
Default Re: What happens when your dif starts to go bad? (top notch)
what happens when you dif starts to go bad???....well if mine went bad I would replace it..but we all don't make the right decision.
Old Aug 29, 2002 | 06:04 AM
Default Re: What happens when your dif starts to go bad? (FitCRX)
Maybe it's just a CV problem. I've noticed that when I have the wheel turned, and try to accelerate, the engine revs, but no (or very little) power is going to the wheels. As I straighten back out, power comes back. I also get this grinding sound...
Any ideas?
Old Aug 29, 2002 | 12:10 PM
ninesecrx's Avatar
Your tires are spinning?
Old Aug 29, 2002 | 12:47 PM
earl's Avatar
I assume it's not and lsd or an auto tranny, correct? I'd look toward the clutch first. Cv's do not slip. They either work or they don't. Trannys don't slip unless they are an lsd.
Old Aug 29, 2002 | 12:48 PM
Default Re: What happens when your dif starts to go bad? (ninesecrx)
Nope. It's like there's no power being transmitted to the wheels, but only when the wheels are turned - usually turned sharply. If they're turned just a little, there's no problem. But say I'm parking with the wheel cranked over. When I hit the gas, the engine revs, but no-go. Or very little go... Maybe it's just the CV joint.
Old Aug 29, 2002 | 12:56 PM
RotaryBzzz's Avatar
That sounds like it *might* be a bad engine ground. One of my previous cars (a Jetta GLI 16v) exhibited the exact same symptoms (engine rev, dash lights ok, no power to wheels, then back on). When you crank your steering wheel, it might be exasterbating the bad conneciton. Check the negative ground to the engine...not just from the battery but the whole negative length...
Old Aug 29, 2002 | 01:17 PM
Default Re: What happens when your dif starts to go bad? (RotaryBzzz)
I'll check and let you guys know.
Old Aug 29, 2002 | 04:42 PM
RotaryBzzz's Avatar
check the negative ground from the ECU too...it should ground on the engine block...(not sure where it is though on honda's - haven't looked)
keegur
Mar 28, 2007 02:52 PM
accord-lude
Nov 23, 2004 01:16 PM
cambopheonix56
Aug 18, 2004 08:21 AM
jayRSX
Jan 21, 2003 07:00 AM
CRX-R
14
Apr 27, 2002 08:00 PM
