Ls-vtec leaking oil onto my tranny...
Old Sep 29, 2009 | 08:09 AM
teamjdm239's Avatar
Default Ls-vtec leaking oil onto my tranny...
leaking oil onto my tranny , i just got a new gsr dizzy, and it came with the oring seal (so i know its not from there.) cant see exactly where its coming from, but when i pop my hood to check it out, i always see the tranny have oil on it. theres always oil puddled underneath the vtec solenoid spot(also near the water neck on the head...)
Old Sep 29, 2009 | 09:20 AM
Mindgamez's Avatar
Default Re: Ls-vtec leaking oil onto my tranny...
HeadGasket
Old Sep 29, 2009 | 09:32 AM
mouab18c1's Avatar
headgasket or cam seal...wipe it clean and examine it while the motor is running
Old Sep 29, 2009 | 09:49 AM
jdoc325's Avatar
yea most likely cam seal if you see it near the vtec solenoid... head gasket doesnt make much sense and you would experiece more problems then that if that was the problem (overheating, smoke, power loss, etc.)
Old Sep 30, 2009 | 09:00 AM
teamjdm239's Avatar
so i degreased my whole bay yesterday, and im at work now... and its oily again. it has to be the cam seal, although it does feel like there is a loss of power... my ls/v should be running alot harder than it is.... cld also be my tune though.
Old Sep 30, 2009 | 10:35 AM
mouab18c1's Avatar
all ls/vtec needs a tune...do a compression test
Old Oct 5, 2009 | 07:25 PM
teamjdm239's Avatar
compression test is 230 across the board. i have ls pistons, type r head, oem headgasket.
Old Oct 6, 2009 | 01:16 AM
93ekg23's Avatar
since u said u replaced the dizzy ill bet its a kragen oriely autozone one.... thats more than likely whr the oil is leakin from, two of mine did it, cheap parts put in it. its a defect in the housing all the o rings in the world dont fix it. if it a cam seal the oil would be visable from the top of the head down, vtec solenoid usually just the bottom bolt area is whr it leaks from. but on the dizzy it'll leak down and make u think ur head gasket is bad b/c u cant see the trail. swap in a known good dizzy and bet me ur prob goes away.
Old Oct 6, 2009 | 07:07 AM
JdmTypeRdc2's Avatar
if its leaking oil INTO your tranny, then its the main seal.
If its leaking oil ONTO your tranny, could be the headgasket, vtec solenoid, or cam seal.
Old Oct 7, 2009 | 03:45 PM
teamjdm239's Avatar
its on to, my tranny , not into. and its the not the vtec solenoid. i checked it and replaced the gasket.
Old Oct 7, 2009 | 03:47 PM
teamjdm239's Avatar
had the original on, and it had the same problem. bought the gsr dizzy from honda.
Old Oct 7, 2009 | 08:52 PM
ivan93egreppin210's Avatar
x2 take off the dizzy cap and see if it has oil inside it. this will take a few mins to check. took me months to figure this out many years ago.
Old Oct 7, 2009 | 09:02 PM
wunfstgsr's Avatar
Loved
Community Favorite
You have a itr head right! im gonna bet you $5 its because you have the wrong distributor see it works! but like me im having the same problem and it started when i swapped my obd2 gsr dizzy for a b16 obd2 dizzy, and now it leaks just how yours is and i know its because its a b16 dizzy! and i also changed the oring twice still leaks so thats my guess lol..
Old Oct 7, 2009 | 09:34 PM
c95gsr's Avatar
I believe its the dizzy, use a OEM TYPE R if you got a R head simple :]
Old Oct 7, 2009 | 10:29 PM
bigislandc2's Avatar
if your really want to find it get some oil dye and use a uv light to locate where oil is leaking from and make sure its clean first.
Old Oct 8, 2009 | 01:03 AM
wunfstgsr's Avatar
Loved
Community Favorite
damn lol thats some mcgyver **** lol but why not just look for where the brown oil is coming from and i believe hes convinced its coming from the dizzy..
Old Oct 8, 2009 | 05:40 AM
timlangston's Avatar
did u ever u the ls-vtec kit
buttascotch_3
Apr 16, 2008 04:30 PM
slowteg140
Jun 19, 2005 05:50 AM
user 996328629
Jun 12, 2004 03:53 AM
2k2silvertype-s
Dec 20, 2002 07:04 AM
