1990 Accord Ignition trouble Help please
Old Sep 28, 2009 | 10:19 PM
chrriff's Avatar
New User
Default 1990 Accord Ignition trouble Help please
Son has a 1990 Honda Accord LX. Car is bone stock with an automatic transmission.
Hes having trouble with the car staying running. Here are the symptoms:
Attempt to start like you normally would,car fires and dies instantly.
Attempt to start and hold the key at a certain position,and the car will stay running. Let pressure off the key and the car will die instantly.
I was actually able to drive the car from where it broke down,to my house with my hand holding the key in a certain position.
So this leads me to believe this is the ignition switch causing the problem. But is this the lock/Tumbler portion or the pigtail/ wiring harness portion causing this trouble?
Id like to know so I dont just throw parts at it.
Whats this sound like to everyone?
Old Sep 29, 2009 | 05:53 AM
redbull-1's Avatar
Default Re: 1990 Accord Ignition trouble Help please
It is most likely the electrical ignition switch, and not the key cylinder/tumbler section.
Refer to this link:
http://techauto.awardspace.com/ignitionswitch.html
Old Sep 29, 2009 | 06:00 AM
jamin's Avatar
Default same problem as mine in my '95.
you have a short in the on position of your elec ign switch- about a $60 honda part.
haynes has a diagnostic test also, but you have discovered the wiggle key test if you can keep the car running long enough to see the effect of the key wiggle.
KaliMist
Sep 10, 2013 02:25 PM
civicgsr116
Sep 25, 2007 08:00 AM
chupowei
Aug 31, 2007 10:56 AM
notoriousB
Jan 11, 2005 03:28 PM
gbarrsh
Jan 29, 2003 08:31 AM
