BLOX log style turbo manifold
Old Sep 28, 2009 | 09:23 PM
em1pusha99's Avatar
Default BLOX log style turbo manifold
I had a question, I am building a ls/vtec turbo and I would like to keep my AC. I was looking at using the blox manifold, has anyone used one, like em or love em? I have herd that on that manifold the waste-gate hits the head. any advice would be great thanks!
Old Sep 28, 2009 | 10:34 PM
eggie75's Avatar
Default Re: BLOX log style turbo manifold
it will hit the hood if you dont use an elbow for the wg. or you can use a turbosmart style wg to get you more clearance. that setup will get you started but, eventually you'll wanna make more power so just go ahead and save yourself the trouble of redoing your setup and get a nice quick 4 ac mani.
Old Sep 29, 2009 | 06:40 AM
hbyrd8701's Avatar
what the hell..... theres a few ppl where I live that are running those manifold and love it. one of my friend making 334hp on 93 and on 110 461hp on a stock b16 for 2 years. Hell I'm about to order one.
Old Sep 29, 2009 | 07:45 AM
project dc2's Avatar
keep in mind you're limited to what turbos you can run on an AC setup
your turbine housing MUST be a 5-bolt ( GARRETT, PRECISION, or FORD design not ebay or any other brand/design like 4-bolt outlets etcc)
otherwise it will NOT FIT**
your compressor housing must be either an "E" or "b" housing because an S-housing is much too large and will not fit.
PM me if you need a 3"AC downpipe, dumptube n wg elbow, we make them for blox setups and if you call them, they will direct you to us.
Old Sep 29, 2009 | 08:19 AM
em1pusha99's Avatar
^ I am glad you mentioned that. The turbo I was about to order for it was the GT3076R. I was hoping it would fit, will it? Also, what's a "nice quick 4" is that a name brand?
Old Sep 29, 2009 | 10:22 AM
eggie75's Avatar
thats spoolin too! pm project dc2. i just picked up a setup from them. looks sooo purdy.
Old Sep 29, 2009 | 11:32 AM
present !
Old Sep 29, 2009 | 11:36 AM
NonovUrbizniz's Avatar
Loved
"Spoolin Performance" (Project dc2) does great work and is super helpful/knowledgable.
Old Sep 29, 2009 | 11:41 AM
em1pusha99's Avatar
well alright Mr. project dc2, will the GT3076R fit on that manifold? what kind of problems am i looking at? your knowledge is appreciated thank you.
Old Sep 29, 2009 | 01:26 PM
not unless you have a 5 bolt turbine housing and a E compressor housing
the std gt 30R ported shroud will not work. nor will the std gt30R 4-bolt bell mouth outlet design
Old Sep 29, 2009 | 09:08 PM
em1pusha99's Avatar
^ um so what would the best turbo to run be, most power with the best fit?
Old Sep 29, 2009 | 10:26 PM
how much power are you trying to make ? what type of racing ?
Old Sep 30, 2009 | 08:40 AM
em1pusha99's Avatar
street car, its got stock sleeves, forged 9-1 je pistons. gs-r head, adjustable skunk cam gears, I would like to make around 350 whp daily. I was looking at the GT2860, and herd from my tuner that was too small. My main goal is 350 whp and AC, will the GT2860 even fit that manifold?
Old Sep 30, 2009 | 09:11 AM
yes if you get the 5-bolt t3t4 ford style turbine housing itll fit perfectly- however it is on the smaller side for 350WHP i'd suggest the 2871R if you want to stick with a small turbo with fast spool characteristics. we can get you that turbo also. PM me
Old Sep 30, 2009 | 10:16 AM
Whatever's Avatar
You should be able to make 350whp on a 57 trim Garrett. I have that manifold and with my Tial wastegate the hood closes just fine without and elbow. I did have to get another exhaust flange to gain enough clearance from the transmission slave cylinder so I could fit a coupler on the turbo. The housing was literally touching the slave cylinder. You'll also have to notch out the webbing on the block.
Old Sep 30, 2009 | 01:15 PM
works on LS without WG elbow. does not work on VTEC heads without elbow
Old Oct 1, 2009 | 07:52 AM
Whatever's Avatar
Ahh... Did not know that.
Old Oct 1, 2009 | 08:05 AM
92redhatch's Avatar
Just buy my sfp manifold. You can keep ac and I had it on my lsvtec making 300+whp $150 let me know
Old Oct 1, 2009 | 08:08 AM
92redhatch's Avatar
And I ran a 5 bolt 62-1 s housing turbo
Old Oct 1, 2009 | 08:42 AM
TheShodan's Avatar
Moderator
Or even the silver surfer would be able to fit, as it is designed in the B cover, fits a 5 bolt ford style housing to allow A/C, 76mm exducer, and makes maximum pressure under 23psi on a GS-r in under 4200rpms, and is capable of over 400whp on 93 octane pump gas. Cool part is its journal bearing so it can be rebuilt, and is $400 less than a GT3076R with no need for additional money for water lines.
Video is posted here from Mitsuman - 346whp @ 11.6 psi. Capable for over 25psi.
https://honda-tech.com/forums/showth...2017644&page=6
Old Oct 1, 2009 | 08:43 AM
TheShodan's Avatar
Moderator
Or even the silver surfer would be able to fit, as it is designed in the B cover, fits a 5 bolt ford style housing to allow A/C, 76mm exducer, 61lbs/min (A GT3076R is about 53lbs/min to 55lbs/min), uses a larger exhaust wheel for more top end power, and makes maximum pressure under 23psi on a 1.8 VTEC in under 4200rpms (about 4500 on a B16).
The turbo is capable of over 400whp on 93 octane pump gas. The Cool part is its journal bearing so it can be rebuilt, and is $400 less than a GT3076R with no need for additional money for water lines.
Video is posted here from Mitsuman - 346whp @ 11.6 psi. and had maximum torque by about 4500rpms. Capable for over 25psi.
A Spoolin' Performance Quick4AC and a silver surfer together would make one helluva combination for an A/C compatible 400whp setup.
Old Oct 1, 2009 | 11:49 AM
Loved
^ Spoolin knows his mani's and Shodan knows his turbo's.
Definately take these guys advice!
Old Oct 2, 2009 | 08:25 AM
silver surfer .. just the name itself is already badass
ARMYEG
Apr 13, 2014 04:36 PM
DelSolMarine
Jan 21, 2007 12:52 PM
matto2413
May 22, 2006 06:00 AM
CivicBwoy
Aug 30, 2005 06:45 PM
fernancivic
Aug 5, 2003 01:49 PM
