Headlights Off = Rear Lights On? Why?
Old Sep 28, 2009 | 09:09 PM
CRXB18C1_ALL MOTOR's Avatar
Default Headlights Off = Rear Lights On? Why?
I woke up this morning only to find out that my car won't start. Charged the battery and it fired right up. As I walked around my car, I noticed that the rear lights were on. However, the headlights were OFF. I'm sure this is why my car didn't start. How is this possible? I then began to pull out the rear bulbs to inspect if any of them were burnt. All bulbs checked out OK.
What else should I check? I checked all the fuses as well. The headlights work fine. Any ideas? Thanks.
Old Sep 28, 2009 | 09:17 PM
alx_90ef's Avatar
Default Re: Headlights Off = Rear Lights On? Why?
its your brake switch at the top of your break pedal
everyone gets this at one point in time.
eighter you get a new one
orr
r
put a peice of cardboard and tape it between the switch and the pedal it self
Old Sep 28, 2009 | 09:39 PM
StayKrafty's Avatar
Make sure its your brake lights and not your actual tail lights.
Old Sep 28, 2009 | 09:43 PM
korywith-a-crx's Avatar
This happened to me last year. I went to the dealership and they said it would be $180. Then another guy said 'o its just the switch on your pedal'
I was under the dash for 20 minutes. The bolt just came loose. My easiest fix ever!
Old Sep 28, 2009 | 09:55 PM
Tyson's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-dont-turn-off-2094313/
Old Sep 28, 2009 | 10:25 PM
.Manny.'s Avatar
Touching My Member
x2
grab a 10mm bolt and nut and pop them in the hole where the original stopper used to be. 20 yr old brittle plastic ftl
Old Sep 29, 2009 | 04:55 PM
michael-crxsi's Avatar
i just had this happen. dont stress it but check your brake arm out. if there is blue stuff on the ground the little stopper fell out. easy fix. i super glued a penny and its worked since
ben05civic
Honda Civic (2001 - 2005)
May 9, 2013 08:22 PM
pearl
Mar 6, 2007 10:55 PM
suspendedHatch
Mar 15, 2006 10:48 AM
VTEC
Jul 2, 2002 12:37 PM
