b series swap NOOB
okay this is my first swap or anything really extensive.but i have a 92 civic dx. what i would like to do is get a b20b(i think thats the right one the one out of a 96-98 cr-v...the one with the lower comp) what will i need etc? is there a write up also i will be doing a trans swap(auto to manual) at the same time.but i do not know what ecu or anything to use cause i'd like to use a LS trans i also planed on getting either hasport or some other mounts.just unsure of what all the mounts other then the auto to manual mount I'd need which i am unsure if I'd even need that.
you my friend need to become friendly with the search button on this site then come back with questions from what you learn doing that. there is waaaay to much to cover in a post like this and you will end up getting confused by what 500 people say and 490 of them wont have a clue.
all im gonna say is when i went d series y8 to LS 1.8 it was a pain in the *** and i didnt even do the swap i only helped. your best bet is to talk to someone who does swaps and let him tell u what u need and whats in your best interest
thing is i am trying to be sneaky pete about this though.
Really not too bad....
Mounts, Shift Linkage, Axles
Those are the main things to get you going, if you didn't know. So much info out there for swapping a B into an EG, it isn't funny!
www.hasport.com will get you goin!
H-T and Google will do the rest!
Check this pretty detailed and with pics. they are swapping a B-series motor as well.
http://www.c-speedracing.com/howto/b18cswap/swap.php
There is more threads on the Faqs under the title "Swaps information"
if your gonna run just b20 stock p75 ls is the best way when you want to do b20v then go with the p28 or like in my case i have a p72 chipped cause i bought super cheap. also you will need a t bracket for your rear motor mount and a half shaft
you also have to change the intake mainifold to a ls intake maini the b20 is way to tall i did my swap in 3 hours went from a d15b8 to a b20b4 im running a stock p28 only it does is makes you have a check engine light and i have advanced auto parts 97 integra axels and avid motor mounts you will need a longer throttel cabel of an integra and larger diamater radiator hoses and integra shift linkage and as far as auto to maunal swap sorry i cant help
If you want facts and not people's opinions do a search on google or go to the faq's.
I usually defend people when hondatech is harsh on them but your being all demanding and stuff. So.... Stop being lazy and do your own research so you can post up your own thread with 100% facts. You can title it "look what i found on google in 35 minutes"
i say p75 stock if your running bolt ons.. im saying that because i did that with my LS on bolt ons and it ran fine.. no need to get fancy when your not even gonna have vtec... ive been through it and im not some lop like some of the guys in here with their mini me bullshit swaps
sohcdestruction
Jan 30, 2008 05:56 AM
HondaTeKnology
Jan 11, 2008 08:38 AM
TheSpoonSwan
Apr 10, 2006 06:52 PM
