FS: various s2000 parts, and speakers
Old Sep 28, 2009 | 02:14 PM
HondamakesS2000's Avatar
Default FS: various s2000 parts, and speakers
*ALL PARTS ARE FROM A 2001 S2000 unless indicated otherwise*
Items for sale:
I have a set of very low mileage 2001 s2k springs and shocks which were replaced at 13,xxx miles. They were replaced for lowering springs, not due to wear (remember, only 13,xxx miles on them). Of course no rust, bending, tension loss, or anything of that sort. If your s2k has over 50,000 miles or are starting to show signs of spring tension loss, this is the perfect deal for you. Also, good for people with ap2, if you want slightly stiffer springs for better handling. Or someone that just wants a set of future replacement springs and shocks. ONE spring and shock assembly is $389 shipped on hondaautomotiveparts.com (your cheapest source for s2k parts btw).
I am asking $250 OBO, for all four spring and shock assemblies (never taken apart). If you need just the spring or just the shock, let me know.
Clutch kit (flywheel, clutch disc, and pressure plate) from the same car, 2001 S2K. The clutch was replaced with an ACT clutch kit at 29,xxx miles. There is still plenty of tread left (60k+ miles if you're not a hard shifter/horrible shifter) on the clutch disc and the pressure plate is in good condition. The flywheel has almost no wear. The ap1 flywheel is lighter than an ap2 flywheel. The clutch disc and pressure plates are the same between ap1 and ap2 (same part #). Flywheels are different, but all parts are interchangeable with either flywheel.
Asking for $200 OBO for the whole kit. If you need just one or two of the parts, just let me know.
Passenger side headlight (genuine honda part from the 2001 s2k) with Rick's grey tinted "smoked" diffusers (makes it look like a JDM headlight). If you want it back to factory, the diffuser can be removed and replaced with the original factory amber color diffuser. The headlights were taken off at 15,xxx miles. In good condition, with only very very fine scratches which I will remove, if you want (they're not noticeable unless you get inches from the headlight), before shipping (I paint cars for a living).
Asking for $225 OBO.
Factory headunit removed when I installed an aftermarket headunit. From the 2001 S2K.
Asking for $50 OBO
Antenna from an ap2. The antennas are all the same for all versions of the S2000, i.e. fits any S2K, not sure about CR, dealership could easily look that up.
Asking for $20 OBO
The leather cover for when the top is down. Never used, stored indoors, in like-new condition.
Asking for $75 OBO
2001 Hood (yellow), replaced for a carbon fiber hood. 2 small stone chips, one is less than 1 mm in diameter and the other one is 2 mm in diameter. The chips are on the front of the hood, about a foot behind the bumper. Otherwise, no scratches that go beyond the clearcoat. That can also be taken care of before shipping but not the stone chips.
Asking for $150 OBO
I also have 2 pioneer reference series speakers (6 1/2'') for sale. I had a four speaker set-up in my celica, but obviously the s2k has only two speakers so I have two spare speakers. They are the non-components; the adjustable tweeter is mounted on top of the 6 1/2'' speaker. These speakers will fit in the s2k without any modifications (I know this since I installed the other two). They are about 2 years old and sound great. Bought both of them for $250.
Asking for $100 OBO for both speakers. Includes original packaging, owners manual, mounting bracket (although not needed), infinity cover, and never-used speaker wires.
Shipping is from MD, zip 21042.
PM me if interested. Thanks.
HondamakesS2000
Oct 3, 2009 07:24 AM
DavidR
Mar 10, 2008 02:05 PM
