Brake rotors
I hope that was a joke. This is the exact opposite of what you should do unless you want glazed pads and warped rotors. I think most street compound manufacturers recommend that you gradually heat the pads and rotors, so no heavy braking for a few hundred miles. Race pads may have other instructions such as a bunch of slow downs without stopping completely from 50 mph to 10 mph and then let them cool all the way.
well... on my Hawk HP+ pads, they instruct you to make 3-4 slow-downs from 40mph to 10 mph, then do a few higher speed stops from 60mph to 10mph. they say not to drag the brakes, just step on the pedal and then let off once your car has slowed down enough. then, you're supposed to park your car for 20 min or so to let the brakes cool down. supposedly when you do this procedure, it helps transfer some brake pad material onto the surface of the rotor, allowing your pads to bite into the rotor better.
the hawk pads are a street/track pad, but i've used this same proceedure on OEM type pads before, and its all worked the same.
dragonkx
13
Jun 29, 2010 07:37 AM
H2290
10
Jul 28, 2006 01:56 PM
Trellis
Mar 12, 2003 04:50 PM
