Pics of my Brake Master Cylinder Brace...
I made a master cylinder brace on the weekend with parts from Home Depot.
The finished product
Installed in the car. No drilling was required to install it.
To see gigantor pics, copy and paste the following links:
http://www.imagestation.com/picture/...b.jpg.orig.jpg
To make the brace more effective you need to add rigidity to it, by making it triangulated.
This could easily be done by welding in another piece of metal as a support.
I used fence post corner ties (simpsons strong ties I think they are called).
Tweak: The brace is black cause I painted it.
Reid: I welded on gussets yesterday but have not taken pics of it yet. There is zero deflection with my brace.
Only the washers I used as bushings are touching the shock tower. I had to use the washers cause the area between the two holes on the shock tower has a bump protruding out.
[Modified by Tommy_Gunns, 2:31 PM 8/28/2002]
Only the washers I used as bushings are touching the shock tower. I had to use the washers cause between the area between the two holes on the shock tower has a bump protruding out.
The shock tower sheetmetal is very thin. I'm not sure if it could happen, but it seems that tearing out that brace (especially if the brace is very rigid) is a possibility.
I highly doubt it would tear of the shock tower sheet metal but I will be going to Home Depot later on to get some larger washers (if it is available).
The washers only affect the one side (where the force is pushing instead of pulling on the shock tower).
You may want to use larger diameter washers.
Could someone quickly explain the science behind needing a brace, and what happens when the brace is there, along with the pros and cons?
I would deduce then that it moves/flexes. So, preventing it from moving/flexes helps how? :confused:
[Modified by drumsy, 4:38 PM 8/28/2002]
It's all about leverage. Think about it this way, you got slippery shoes on and your pushing against a wall, if you secure your feet, you will push with a greater force.
Bad analogy but you get the point.
[QUOTE-Tommy who thinks H-T should have a finger icon
[/QUOTE]
me too
but i just niced that tweak had one last week... maybe i should join in on the fad? huh , wadda ya say?
[/QUOTE]me too
Tommy! Nice DYI! Makes me regret the LHT brace purcase just a little bit.
Whatever happened to GHETTO!???
here is one that i made up at work. first one so i'm going to make some changes to it. i've used it at VIR for a three day event and it worked great!
sorry bout tha size...
looks good
thanks! a few measurements and AutoCAD on the home computer....
i'd like to make a few more mods to it and then make another one.
