91 dohc zc into 95 si, possible?
Old Sep 28, 2009 | 08:10 AM
unlucky's Avatar
New User
Default 91 dohc zc into 95 si, possible?
I've got 2 si's 93 and 95, auto and 5 speed respectively, also 95 lx auto, 93 lower bearing making noise 300k on it, 95 also 300k starting to burn oil, lx running on three cylinders, have the zc sittng in my shed, was in my 90 dx h-back, scrapped that, kind of in a jam and was hoping somebody would have some info on if and how to fit the ZC into my 95 si, thanks!
Old Sep 28, 2009 | 10:45 AM
FRESHTEG's Avatar
Default Re: 91 dohc zc into 95 si, possible?
u could put it in no prob just convert the motor 2 obd1 and drop it in
Old Sep 28, 2009 | 10:56 AM
unlucky's Avatar
New User
thanks it looks like it will fit, the mount coming off the block on the zc looks a little offset compared to the z6, i was wondering if the mount from the 95 will bolt right up to the zc, also by changing the motor to obd1 do you mean changing the plugs so they will plug into the 95 harness and could i use the stock ecu leaving the v-tech unplugged, thanks!
JCORTES
Oct 28, 2013 09:57 AM
EJ1_samson
Nov 14, 2009 08:33 AM
ej8 nacho
25
Dec 18, 2008 09:37 PM
labatia
May 9, 2004 07:18 AM
