Honda S2000 Honda S2000
White smoke question
Old Sep 28, 2009 | 06:38 AM
llozll's Avatar
Default White smoke question
hopefully it's not an head gasket, but..
i juss wanna get some inputs from you guys since it's not too much of an white cloud smokes..
i get a little white smoke when cold start. well i don't smell any sweets and white smoke comes out for like a 5 seconds and then that is it.
i thought it's because of the temp being low in the morning.. juss getting a steam, but i get the same amount of white smoke after work (car's been parked outside in the 90 degrees for like 9hours). it's 06 s2k juss hit the 30k mi. so need to get a 30k mi service.
what are the thoughts guys? help me out!!
Thanks,
OJ
Old Sep 28, 2009 | 06:58 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: White smoke question
i think ur fine... if its an 06 take it to the dealer... should still be under warranty...
Old Sep 28, 2009 | 08:03 AM
llozll's Avatar
bought it as used car, not certified.
well i think drive train is covered by 60k/5yr warranty but.. it only covers defects.. though. hm.. thanks for the input s2killa!!
any other inputs?
Old Sep 28, 2009 | 12:30 PM
llozll's Avatar
bump for eagering new inputzz guyz
Old Sep 28, 2009 | 12:42 PM
Jdm=Ep3's Avatar
you should be fine their is always moisture in the air
turbosix.net's Avatar
its a drivetrain warranty... take it to the dealer
Old Sep 29, 2009 | 06:18 AM
White Smoke's Avatar
i my honda
Global Mod
First, check and see if you are getting any oil water mix... Is your oil level dropping? Take off the oil cap, shine a flashlight in there and see if you see a milky substance. If you have access to a compression or even better, a leakdown tester those would be great tests to run.
Old Sep 29, 2009 | 08:18 AM
SirStig's Avatar
should be covered. take it to the dealer. IMO it's just water somewhere probably condensation
Old Sep 29, 2009 | 10:31 AM
llozll's Avatar
thanks for the inputs guys.
i truly appreciate it!
i will take it to the dealer this weekends and see wut's up!
thanks again,
OJ
Old Oct 3, 2009 | 08:47 PM
Jdm=Ep3's Avatar
thanks again,
OJ
pull your dipstick out when car is running. drop a drip of oil on the exhaust...if it smokes and no bubles your good.. if it bubbles their is water or coolent in their
Patrick Jordan
Sep 9, 2012 04:19 PM
rx7_
Aug 5, 2009 05:44 AM
javon214
Jul 10, 2008 05:58 PM
davejj40
Sep 30, 2004 12:36 PM
bitr364
Mar 10, 2003 06:53 AM
