Accord A/T bearing failure diy questions
Old Sep 28, 2009 | 05:45 AM
onthe3rdday's Avatar
Default Accord A/T bearing failure diy questions
I have the whirring/ roaring bearing failure noise coming directly from the torque converter housing area. I'm going to replace the converter housing bearing and maybe even the case bearing. Has anyone done this w/ Honda's auto trannys before. I'm trying to be ready for any unforseen problems. 98 accord 4cyl EX-ULEV.
Old Sep 29, 2009 | 05:13 PM
jhondayang's Avatar
Default Re: Accord A/T bearing failure diy questions
it's the diff bearings that is bad. move your axles on the inner back and forth. there should be minimal play, if there is a lot of play, the diff bearings are bad.
Old Sep 30, 2009 | 04:19 AM
I doubt it... but here is why. In order for the diff bearing to make noise, it has to move. I get the noise when the tranny is in park and neutral. I have next week off from work and I'm gonna pull out the tranny then.
Old Oct 1, 2009 | 04:53 PM
First obstacle... Seems like these auto trannies need a housing puller to separate/ remove the transmission housing. The ESM references part number 07hac pk40102----
Old Oct 2, 2009 | 04:03 AM
Ok that obstacle is resolved. Now the next obstacle is what if I need that arm extension attachment for the housing puller! Someone who's done this before. Please PM me or somethin
tdrolin123
Transmission & Drivetrain
Oct 17, 2008 10:09 PM
vg7z
14
Jul 23, 2005 06:33 AM
shortyz
14
Jan 11, 2003 12:52 PM
