90 civic horn problem
got an aftermarket steering wheel. and my horn dont work. so i took it off and to see if it was plug in but idk which one is it. any body know ? cause i know for 92-95 civic there a yellow plug.
there should be a wire that connects your horn button to the metal slider on the steering column. Thats the only wire that needs to be reconnected when installing an aftermarket wheel.
If thats connected and the metal ring/slider is clean of grime check your horn fuse. Or hell check the fuse first
oh alright. let me check it out. thanks
HondaMechanic24
Jun 21, 2014 11:57 AM
