H22 transmission problem need help
Old Sep 27, 2009 | 06:14 PM
bb62o3's Avatar
Default H22 transmission problem need help
I have 99 prelude type sh with a jdm type s motor and tranny. my problem is i cant get it into gears smoothly, sometimes i have to turn the car off to get it in gear at a full stop. when i push the clutch all the way down and have it in gear and try to start it sometimes the car still goes, any 1 with this problem and have any idea what this is??
Old Sep 27, 2009 | 06:37 PM
night's Avatar
Default Re: H22 transmission problem need help
needs master/slave cylinders
if slave is leaking then just change it, but if master is leaking go ahead and change both.
Old Sep 27, 2009 | 06:39 PM
kd97accord's Avatar
^^^^^^ like he said, slave cylinder could be gone , or you are leaking fluid and not know it.
Old Sep 27, 2009 | 07:34 PM
Enzo15's Avatar
Could his clutch be out?
Old Sep 27, 2009 | 07:47 PM
night's Avatar
could if it was coming apart, but i'm sure his story would have been different.
Old Sep 27, 2009 | 07:48 PM
R666_EK's Avatar
If the clutch disc is shot, it would be at the least slipping. A worn clutch disc most likely won't cause issues getting into gear.
This problem definitely seems to be with the clutch not engaging/disengaging properly, which means its most likely the fault of the slave or master as previously stated.
Old Sep 28, 2009 | 12:05 AM
TheJGB3's Avatar
Could be clutch master and/or slave cyls or Clutch is probably going out.
Old Sep 28, 2009 | 03:37 AM
PirateMcFred's Avatar
If the fluid is just low it could just need a simple bleeding. A worn disk won't cause the issues the OP is experiencing. Chances are that the slave cylinder's going bad. Just pull the rubber boot back on the front of the transmission and see if it's got fluid in there.
Old Sep 28, 2009 | 12:46 PM
bb62o3's Avatar
Good looks, The clutch is fine and i have no leaks, could be the slave cylinder, i gotta check it out
bigdem1civic
Transmission & Drivetrain
Mar 13, 2014 05:50 PM
phatsindabuildin
Mar 25, 2008 06:57 PM
sniperslayer
Nov 6, 2005 10:00 PM
ludelvr
Aug 20, 2003 10:00 PM
ludelvr
Aug 13, 2003 10:54 AM
