FALL CLEAN UP SALE!!!! something for everyone.B.D.F.turbo stock ect look.
Old Sep 27, 2009 | 05:42 PM
goldhatch94's Avatar
Default FALL CLEAN UP SALE!!!! something for everyone.B.D.F.turbo stock ect look.
ok guys well i started to do clean up in my basement and in my shop to make room for the winter so there is lots of parts i have no need for and really not lookin to make a million off it all just like to make some room so pleses no trades.
all prices are OBO unless stated FIRM.
you must also add in for shippin a 3% if payin threw pay pal.
if something is no pictured just pm me and i will take pictures for you if you want more detailed pictures also pm me and i will take some more.
and sorry i will not ship any thing out of the USA maybe canada but i had to much BS with other places dont want to do it any more.
all parts are also sold AS IS!
well here we go !!!
D16A6 crank shaft pulleys i have 3 of them on has rubber damanper in it looks to be stock
20$ each obo
D16Z6 vtec solinoid broken plug and broken presser sensor
20$obo
USED TYPER oil pump ruffly 1k miles on it pulled from the motor with bent valves
60$ obo
one full set of OBD2 injectors
25$ obo
one full set of OBD1 injectors with the safty stopper in the center
25$ obo
one full set of OBD1 injectors with safty stopper on the ends
25$ obo
D16A6 fuel rail with obd1 injectors and feed line
30$ obo
2 D16z6 fuel rails
20$ obo
D16Y8 fuel rail with FPR
25$ obo
2 bolt motor bracket
25$ obo
one full set of stock motor mounts from a 94 civic dx
50$ obo or will spilt up pm me
D16z6 lower timeing belt cover
20$ obo
B sreies tranny mount older one
25$ obo
misc shinny bent intake pipe with coupler
25$obo
GSXR 1000 ITB's good for the home made ITB guy
50$ obo
GSR/TYPER 22T water pump 1k miles on it
25$ obo
EF civic 2 bolt motor mount
20$ obo
D16Z6 timeing belt tenisinor
20$ obo
20'' Long earl SS oil feed line never used lost package but rember it cost me 29 bucks
20$ obo
4 16valve sohc valvecovers
25$ each
D17 coil on plug vlavecover
25$ obo
D15 valvecover
25$ obo
LS b18a1 valve cover powdercoated gloss black
50$ obo
SOHC VTEC accord valve cover powdercoated gloss black
50$ obo
ractive hedder rusty and the flang missing where it would bolt to the exhaust
25$ obo
ebay Rear strut bar
20$ obo
B18a1 intake manifold
20$ obo
B16a intake manifold
25$ obo
2000 GSR rack&pinion with tir rod ends on it
75$ obo
one NEW IN THE BOX B series axle driver side from autopart internotal
70$ firm
used passanger side ruffly 1k miles on it axle
50$ obo
hydro mid shaft B series
50$ obo
used B series starter 1k miles
50$ obo
D16Z6 block notched for forged rods empty
50$ obo
B20 crank pulley
40$ obo
2 /3 bolt motor brackets
20$ each
LS upper timeing belt covers
30$ obo
2 IACV
20$each
long throttle cable DPFI maybe
20$ obo
used 2k miles d16z6 oil pump with pick up
30$ obo
used unknow miles d16A6 oil pump with pick up
25$ obo
5 wire obd0 dizz
30$ obo
JDM D15B vtec-E head 4 new vlaves hot tanked and bence valve adjusted with stock JDM intake and injectors and Z6 valvecover.
200$ obo
Z6 intake manifold
30$ obo
EG cluster with tach stick shift
50$ obo 200k on it.
unknow sohc vtec aftermarket cam shaft no marking on it idk the brand lobs are def bigger tho then stock
100$ obo
BNIB HAsport hydro trans coversion for EF
220 FIRM
MINT gsr hydro trans lower miles never any grinds or pops loved this trans vin still on it with car fax report in hand.
550FRIM
ProLight B series flywheel fresh cut 1k miles on it
75FIRM
come clutch stage 4 6 puck unsprung 1k miles on it
300 OBO paind 395+shipping so dont low ball it.
LS/Vtec motor BUILT for turbo ran it for 3k miles tops never got any chance to dyno or track run it just break in and daily drivein and then lost my licens in the car sold the rollin shell on here about year ago and had planed to put the motor in my CRX but i am going back to the D series in it so this must go.
i will part the head from the lower end and that about all i will part from it sorry just dont want to pull apart a good running motor.
B18a block .20 over
wisco pistons
eagle rods
knife edged and balanced crank
oem berings
typeR oil and water pump
new seals
arp head studs
B16 head
all new valves
gsr cams
comp springs and retainers
AEBS intake manifold
3k obo for the whole thing pm me for part out prices.
next is the motor in my CRX now
B18A ruffly 160k on it
new timeing belt and water pump
act clutch
mint cable tranny.
i will sell it as a swap with Axles HAsport mounts for EF and linkage with OBD1 dizz for 750FIRM
or sell just the motor trans dizz for 500FIRM.
the motor is still in my car for sale so any one in the are i will take for a ride befor pullin it only if you show with cash will i do it tho and i will not pull the motor till i get paied in full for it sorry guys.
now for pics any thing you see listed not in a pic pm me and i will take some for you,
thanks for looking
Old Sep 27, 2009 | 05:44 PM
Default Re: FALL CLEAN UP SALE!!!! something for everyone.B.D.F.turbo stock ect look.
Old Sep 27, 2009 | 05:47 PM
WOW UPDATE ALREADY
forgot theses
twin turbos off a Supra unknow year bought them for used of the turbos never did
one looked to be new or replaced the other has a chips on the fins both have no play and spin freely will not pull them off the manifold
200$obo they are heavy so shippin will cost a bit!!!!
Old Sep 27, 2009 | 05:53 PM
pictures of the LS swap in the crx
Old Sep 28, 2009 | 04:22 AM
up top
Old Sep 28, 2009 | 05:36 AM
KdF's Avatar
KdF
How much that flywheel weigh?
Old Sep 28, 2009 | 01:11 PM
75FIRM
it was listed in the post
Old Sep 28, 2009 | 04:45 PM
bumpo
Old Sep 29, 2009 | 07:05 PM
no one need any thing
Old Sep 30, 2009 | 01:53 PM
up top
Old Oct 1, 2009 | 04:37 AM
up top
Old Oct 1, 2009 | 03:16 PM
bumpo
Old Oct 2, 2009 | 04:32 AM
parts for sale
Old Oct 3, 2009 | 08:35 PM
Xperience's Avatar
up and pm'd
Old Oct 4, 2009 | 07:21 AM
ok i will get pics and get back to you
ALSO TURBO MANIFOLD SOLD!
Old Oct 4, 2009 | 07:24 AM
Xperience's Avatar
Alright thanks man.
Old Oct 5, 2009 | 01:15 PM
Tetanus's Avatar
bump for you
Old Oct 5, 2009 | 04:56 PM
still for sales
Old Oct 5, 2009 | 05:03 PM
Originally Posted by Xperience
Alright thanks man.
hey man sorry to say but i must have sold the b16a intake manifold i went to take a picture for you and it is gone!
Old Oct 5, 2009 | 08:33 PM
midnight bump
Old Oct 9, 2009 | 02:59 PM
up top stuff still here
ITB'S sold
Old Oct 11, 2009 | 10:56 AM
still got some stuff guys help me make room
Old Oct 13, 2009 | 11:30 AM
doobs's Avatar
bump, sent you a pm
Old Oct 13, 2009 | 03:16 PM
pm's replied stuff needs to go guys
Old Oct 14, 2009 | 03:13 PM
up top
