Suspension & Brakes Theory, alignment, spring rates....
Non-koni GC sleeve to be installed on a Koni
Old Sep 27, 2009 | 02:32 PM
STN_Pat's Avatar
Default Non-koni GC sleeve to be installed on a Koni
Hey
Will a non-koni Ground-Control sleeve fit correctly on a Koni by using the standard spring perches ?
Thanks
Old Sep 27, 2009 | 02:51 PM
racebum's Avatar
Default Re: Non-koni GC sleeve to be installed on a Koni
uh huh, provided the GC's are for honda/acura shocks
Old Sep 27, 2009 | 03:21 PM
STN_Pat's Avatar
Yes, they are Honda Civic GC for non-koni shocks.
I was just worried about the O.D. of the Koni, but I was pretty confident they would fit.
Thanks for confirming it.
Old Sep 27, 2009 | 11:01 PM
sayyoooon's Avatar
don't you need the adapter so it sits properly?
Old Sep 28, 2009 | 11:52 AM
TunerN00b's Avatar
Originally Posted by STN_Pat
Hey
Thanks
Yes, they'll fit, but don't do it. It isn't a safe thing to drive on, as those spring perches were not meant to support the weight placed on the location the GC sleeve will. They're meant to take the weight on the outside edge, where a spring would sit.
The only safe way to run GCs on Konis is with with the Koni specific GC sleeves, or the Koni adapter for standard GC sleeves (which I don't think they make any more).
Old Sep 28, 2009 | 04:54 PM
STN_Pat's Avatar
They are no worst than GC on any shocks; wich are neither designed to hold a spring perch
Old Sep 28, 2009 | 05:04 PM
TunerN00b's Avatar
They are significantly worse, actually.
Normal shocks mount the spring perch directly to the shock body.
Koni Sport shocks (Yellows) use a groove in the shock body, fit a circlip into this groove, then lay the spring perch over the circlip. For the circlip to stay where it needs to, you need to load that spring perch correctly. This is why GC makes Koni specific sleeves...
Wait, didn't you ask the original question?
Anyway, this has come up many times here on HT, and the answer has always been the same from Koni, only use a sleeve that was intended to capture the circlip, never use a sleeve on top of the Koni spring perch.
Anyway, your car, your money, your life, do as you please.
Old Sep 28, 2009 | 05:10 PM
zGo's Avatar
zGo
I don't get why you would ask a question and then turn around and be the expert with someone who's trying to help you.
The obvious thing to look at would be why would they make a 'Koni-specific' GC if the regular ones were just as reliable and performed the same. That's your answer.
Just becase you CAN eat Raviolis out of a flip-flop doesn't mean it's the best and most efficient way to get the job done, especially if there's a Ravioli specific bowl available for your eating needs.
Old Sep 28, 2009 | 05:16 PM
STN_Pat's Avatar
With what key words may I find these thread ?
Old Sep 28, 2009 | 05:29 PM
STN_Pat's Avatar
Oh and to make this thread constructive and helpfull, GC does sell the Koni adaptors to make any sleeves fit...
Anyway...my money, my life, my car and my dumbness were you saying. Thanks anyway.
Old Sep 28, 2009 | 05:59 PM
beanbag's Avatar
Really, all you need is an adapter that slips OVER the circlip and presents a FLAT surface for the sleeves. Then something that keeps the sleeves centered if they are a loose fit. I've made adapters for my Bilsteins that have the same circlip groove mounting system.
Tuner is right, DO NOT use the spring perches designed for springs with a cut end, as that will not present a flat surface for sleeves to rest on.
Old Sep 28, 2009 | 06:07 PM
TunerN00b's Avatar
I thought those were discontinued.
Nope, not your "dumbness". Simply, your responsibility to verify that what you read here and elsewhere before you decide to do anything.
I can't say I've never been wrong, as I certainly have been, and will be again in the future. But I can say that while I try to provide correct information, its still on the reader to verify it, trust it, or ignore it (your choice).
I've tried searching, and can't find a good thread discussing seating a threaded sleeve on a Koni's spring perch at the moment, but I'm also trying to get out of this office and go home so my heart isn't exactly into it.
*edit: You have "thanks Lee @ Koni" in your sig. PM him and get the final answer.
Old Sep 28, 2009 | 10:46 PM
Design's Avatar
CRX Lee has posted on this topic a few times.
Basically, the GC sleeve can put uneven pressure on the perch/circlip and cause it to separate from the shock body. There have been a couple members over the years who have had the circlip fall through, causing the entire corner of the vehicle to slam onto the bump stop.
Here's more:
Originally Posted by CRX Lee
If you as using a threaded coi-over sleeve perch system, that system must also fit properly and have a groove in the bottom side to perfectly capture the circlip. Do not put a grooveless coil-over sleeve on top of a KONI grooved spring perch and hope that it holds up. The sleeve must fit right and have its own groove. To my knowledge, only KONI and Ground Control make sleeves specifically grooved for KONI circlips. In 12 years of working for KONI, I have never seen or heard of a truly well fitted grooved coil-over sleeve system or spring perch ever fall down or fail but I have heard of plenty of ill fitted or improperly installed ones fall down. The system is very strong and allows adjustability that a welded perch does not allow but it must be used correctly or it is wrong and at risk of problems.
https://honda-tech.com/forums/suspension-brakes-54/koni-yellow-circlip-perch-2227349/
Old Sep 29, 2009 | 11:32 AM
STN_Pat's Avatar
thanks a lot
Old Sep 29, 2009 | 10:56 PM
emooheo's Avatar
I have a question about this as well. I am running non-koni GC's on my koni yellows.
Not sure if you guys will understand me exactly, but ill give it a shot.
The circlip has a metal ring that goes over the top of it. The rings inside diameter is the same as the shock, but extends out to provide more surface for the sleeve to sit on. Does this come with the konis or ground controls? Could it be some short of adaptor? I cannot find pictures of one online anywhere..
Old Sep 30, 2009 | 11:43 AM
TunerN00b's Avatar
Sounds like some form of adapter to me but without a picture I'm guessing blindly in the dark.
Unless it is the Koni supplied spring perch you are talking about, that sits directly on top of the circlip, in which case you have a failure waiting to happen on your car.
Old Sep 30, 2009 | 01:52 PM
Design's Avatar
That is the retaining ring and is used to hold the circlip in place to prevent it from separating. The perch sits on top of the circlip/retaining ring. I believe it comes standard with the rear shocks only on certain applications. The standard GC collar does not sit flush on the perch, so there's a risk that it could separate under extreme conditions.
Old Sep 30, 2009 | 08:02 PM
eklum's Avatar
the way the gc koni perch is made it would keep the snap ring in a uniform position thus keeping the perch on the shock if there was uneven pressure it would be possible for the snap ring to fall off infact likely!
Old Sep 30, 2009 | 10:40 PM
STOCK_SOHC_DX's Avatar
If you run the non specific sleeves on the OE style perch this will void your warranty. Since those adapters might be discontinued I would tell you to try the skunk2 adapters but that would probably void the GC warranty.
Old Sep 30, 2009 | 11:19 PM
emooheo's Avatar
Can you provide a link to such adapter?
Also, if i buy new sleeves do i need both front and back?
Old Sep 30, 2009 | 11:32 PM
https://honda-tech.com/forums/suspension-brakes-54/not-write-up-write-up-skunk2-konis-2592526/
Old Sep 30, 2009 | 11:58 PM
emooheo's Avatar
nice! thanks man. I have found them for about $15 but the description is vague and doesnt state if it is sold individually or in a pack of 4
Old Oct 1, 2009 | 02:07 AM
It is sold in pairs.
team_hirev
Suspension & Brakes
Mar 5, 2009 09:41 AM
bopbop93030
Suspension & Brakes
Jan 19, 2009 05:14 AM
PowerLeg
Suspension & Brakes
Aug 19, 2008 06:22 PM
Bastion
11
Mar 22, 2005 09:25 PM
Eggman
Feb 18, 2004 10:57 AM
