Honda S2000 Honda S2000
replacing Softop, what is grey foam on rubber trim?
Old Sep 27, 2009 | 02:23 PM
JasonST's Avatar
Default replacing Softop, what is grey foam on rubber trim?
Hey guys I'm in the middle of replacing my 00 soft top with a glass ez on top. I had a question. I'm taking off the window trim pieces and the pieces below it, and there's this sticky foam to help seal/stick the trim in place. I was wondering if I have to replace this sticky foam when putting on the new soft top and where I get it at? Thanks,
-Jason
Old Sep 27, 2009 | 04:47 PM
4doorH22's Avatar
Default Re: replacing Softop, what is grey foam on rubber trim?
I've never messed with the top, but it sounds like you're describing "EPT sealer." I've never seen an individual part number for it, but I'd check out a dealer. It also seems to be any of the stuff called "SEAL, TAPE" here.
Old Oct 1, 2009 | 06:12 AM
TPhong's Avatar
Unless it is a rubber trim bar that sticks above and below the plastic back window. Don't think you'll need it if you're replacing it with a glass top. Only the MY00-01's have it.
peAches yO
Nov 22, 2011 10:27 AM
Eyger
Paint and Body
Sep 23, 2009 09:19 PM
AzCivic1.6
May 28, 2005 08:50 PM
nuckingfuts
Apr 30, 2005 07:42 AM
Sabbotage
Apr 10, 2005 10:05 PM
