Stripping Paint off my car.
Old Sep 27, 2009 | 01:01 PM
gqstatus05's Avatar
Default Stripping Paint off my car.
Want to strip all the paint off my car. What's the quickest way?
Old Sep 27, 2009 | 04:30 PM
gorillafart's Avatar
Default Re: Stripping Paint off my car.
aircraft remover... sand the whole car first with like 150 or something... then apply the arcraft remover... and let it sit.. then scrape it off
Old Sep 27, 2009 | 05:09 PM
bakertime's Avatar
Why do you need to strip it all off? OEM primers are about as good as it gets for corrosion resistance. Striping the paint should be a LAST resort....usually you can just sand the topcoat.
Old Sep 27, 2009 | 06:14 PM
prelude1897's Avatar
exactly...If you're planning on repainting the whole car, all you have to do is scuff up the clear, cause the base coat will act as your primer unless if the paint has just gone to crap and is cracking all over the place
Quickgti1.8t
Paint and Body
May 26, 2007 11:17 AM
