Suspension & Brakes Theory, alignment, spring rates....
EP3 Brake woes. GranSport
Old Sep 27, 2009 | 12:42 PM
Natural Aspirations's Avatar
Default EP3 Brake woes. GranSport
Recently purchased an 05 Si and brakes were close to needing replaced (Original Pads and Rotors) and had some pulsation. After reading reviews and finding something that meets my tightish budget I went with Satisfied GranSport pads and had my rotors turned, spent $140 total for front and rear.
After fighting the rotor screws on the way off, I got everything off checked pins for play and lubrication, cleaned and re-installed. Opened the bleeder when I pushed the calipers in to bleed off the dirty fluid and turned in the rear calipers. Bled each caliper 3 pumps to check for air and flush fluid a little, found no air and little dirty fluid.
On to bedding pads per instructions 10 times from 30-10 with 30 second intervals and 5 stops from 50-10. (Possible problem is that it was raining quite hard)
I feel that I performed proper procedure but pads lack any initial bite, I cannot figure out where I went wrong the car does stop but with much pedal effort. I read the reviews on these pads before purchase and the GranSport GS6 pad got great reviews on tirerack and commented on "initial bite".
Advise?
Old Sep 27, 2009 | 03:08 PM
shortstopNE's Avatar
Default Re: EP3 Brake woes. GranSport
i had my g/f pump the brakes til they were stiff, i'm not sure about pumping it 3 times to get it done or not.
cmyates007
18
Apr 14, 2012 10:19 PM
oMek
Jun 9, 2006 12:30 PM
PH3593A
Jul 28, 2004 03:14 PM
LillDragun
Jun 6, 2003 11:04 PM
internet ay
Apr 28, 2002 07:32 AM
