new pistons:) some questions
Old Sep 27, 2009 | 10:10 AM
kornkid21792's Avatar
Default new pistons:) some questions
So im buything these pistons i forgot the name but its 9:1 compressions and there forged and heat coated performance pistons all around
i was just wondering will i c a gain over stock pistons? and what other benfits there will be
thanks love u all
Old Sep 27, 2009 | 10:29 AM
street_ride14's Avatar
Default Re: new pistons:) some questions
No gain over stock,
you will actually lose horsepower because of lower compression and scratch up your cylinder walls ( FRM does not like forged. )
Old Sep 27, 2009 | 11:09 AM
wow thats wierd i thought f22a already had low compression?and sorry but wat does frm mean
Old Sep 27, 2009 | 11:16 AM
nv, I thought you had the h23 .. f22a compression ratio is at 8.8 : 1 stock, so your 9.0 is slightly higher .. a little gain in power then, and no worry about FRM .. your block should have iron sleeves
to get the most out of those pistons would require you to tune and no longer pump using 87 fuel.
Old Sep 27, 2009 | 11:25 AM
ok thanks muchmy car is going to love me after i put those in considering its still the 17 year old stock ones.
thanks for your help and what you thinking like 10 hp maybe?
Old Sep 27, 2009 | 11:29 AM
consider this .. you probably have some carbon build up on those stock pistons. That alone is enough to bump up your compression ratio to 9.0 on those stock pistons .. so, not much gain at all for you in the end.
Old Sep 27, 2009 | 11:38 AM
well i guess i will still see a lil bit of gain wich is ok for me as long as its some gain plus the guy that had the lude b4 me treated it like **** so itll be nice to put some performance internals in there.
Old Sep 27, 2009 | 05:47 PM
R666_EK's Avatar
If you are gonna be tearing into the motor anyways, why not go with a higher CR or do a complete rebuild? You say it was treated like **** so I would at least.
BTW, like Street_Ride14 said, you won't even notice the difference. Unless you are losing compression as it is. But compared to another stock f22, you won't notice.
Old Sep 27, 2009 | 07:07 PM
idk i was gonna turbo it. well what would i gain out of 12:1 compressions or 17:1 compression bisi makes thoughs
Old Sep 27, 2009 | 07:28 PM
dagle's Avatar
12:1 you'll have a torquey F22, 17:1 you'll be without a motor
Old Sep 27, 2009 | 08:51 PM
so what shld i do get the 9:1 or get 12:1
Old Sep 27, 2009 | 10:07 PM
jnv255's Avatar
if your going turbo, 9:1.
you need to make your mind up on what you want to do in the future, i would go turbo, but thats your call.
Old Sep 28, 2009 | 05:49 AM
PirateMcFred's Avatar
lol, I vote for 17:1 CR and 40 PSI boost on straight toluene. That would rip. :D
Old Sep 28, 2009 | 06:42 AM
NirVTEC's Avatar
Can't believe the posts I am seeing these days.
10yrs of Archived threads.............WTF?!?!?!
Old Sep 28, 2009 | 08:17 AM
i am for sure just gonna turbo
lol sorry nir
j0nb0y22
Oct 3, 2007 12:17 PM
rasinhell
Jul 20, 2005 12:58 PM
Derek14
Feb 29, 2004 03:35 PM
TurboNOSlude
Jun 22, 2003 09:59 AM
DLB1994
Aug 3, 2002 02:52 PM
