FS: Y8 Dizzy / VDO / Valvetrain / OE Muffler / H22 / Del Sol
Located in SE Michigan - 48360
Shipping is EXTRA and will be added to the cost listed below.
(For example: No, I will not take $35 shipped for the guages.)
VDO Vision Series Gauges - Boost/Vac and Water Temp
Brand new, never used, just installed.
Boost/Vac gauge comes with vacuum line with fittings and Tee for tapping into hoses.
$35
Price @ 42DraftDesigns = $32 without the line
http://*******.com/a7v7wp
Also, Oil Temp gauge that is the same series as the ones above...
Its still installed and would take some extra time to remove.
Retail on it is a little over $25 w/o sender.
Sender that I have fits M14 oil pan drain plugs, so nothing needs to be drilled/tapped and gives overall oil temp of the entire engine. Retail $12.
Gauge WITH Sender $30
I'll sell both gauges together, with sender and line for $60
OEM GSR Valvetrain (springs, keepers, retainers)
Dual springs @ intake.
$25
Del Sol OEM hood pop handle
Brand spankin new. Friend bought it, didnt need it. Its mine to do with what I will.
# 74130-SR2-A00
Includes both handle parts (base and lever) and rubber grommet for exiting firewall.
$20 ($32 @ dealership!)
EK Hatchback OEM Muffler
There was some rust on the outer shell but NO holes. I shot the area with rust converter.
$20 OBO
ITEMS SOLD:
h22 intake manifold
d16y8 distributor
$35
$25
# 74130-SR2-A00
$20 OBO
ITEMS SOLD:
h22 intake manifold
d16y8 distributor
How much for shipping for the H22 manifold to zip 74467 (oklahoma) the guy I bought the car from put a thermal gasket on and didnt tighten the bolts right and now its cracked..
