97 accord corner light and tails lights wont turn off
does anyone know what is wrong? my corner lights in the front and the tail lights in the back plus those two small lights on the side will not turn off even when the key is taken out. at first i replace the interior fuse box and that fix the problem for like 2 days and now the lights will not turn off again!!!! my battery was getting drain like crazy this morning it almost iddnt started
Have you checked all the bulbs? Check all of them!
Check the fuses too.
After that, inspect the wiring, see if there's any wire exposed that is making contact with something that it shouldn't, anything melted?..
Also, Did you turn the switch to off on the left side of the steering column? I did that once without realizing I had to make two small turns to turn all the lights completely off. Maybe the switch is dirty and is getting stuck in the 1st position? You may also check for a relay under the hood or in the interior fuse panel that may be stuck.
Soulman41
Sep 25, 2014 10:00 AM
