Suspension & Brakes Theory, alignment, spring rates....
ITR Front Sway Bar - Anti Roll Bar on EG
Old Sep 27, 2009 | 02:40 AM
c_trick's Avatar
Default ITR Front Sway Bar - Anti Roll Bar on EG
Hi all.
Could anybody help me?
Is it possible to install a 24-25mm ITR front sway bar on Honda Del Sol SI without changing OEM SI front lower arms (by SIR or ITR lower arms) and without risk for them?
I upgrade my suspension by an ASR Subframe + EDM ITR 22mm rear sway bar and i'd like to finish it!!!
Old Sep 27, 2009 | 05:23 AM
IN VTEC's Avatar
Default Re: ITR Front Sway Bar - Anti Roll Bar on EG
As long as you already have the holes in the front LCA's to accept the swaybar endlinks, then it'll be just fine.
Old Sep 27, 2009 | 10:12 AM
Egezzy's Avatar
Spongebrad Squarepants
you will need integra endlinks. eg/eh endlinks are different ten integra.
Old Sep 27, 2009 | 10:25 AM
c_trick's Avatar
OK men.
Thanks.
So ITR front sway bar will fit on Del Sol SI without modification.
Just add the ITR endlinks with the bar.
Old Sep 28, 2009 | 03:28 PM
IN VTEC's Avatar
Yeah, forgot about the endlinks. More specifically they need to be GS-R or ITR endlinks. The LS swaybar endlinks are similar to the Civic's.
BoostKiller
Northwest (Sales)
Sep 21, 2008 12:20 PM
phatcivic99
Nov 27, 2003 07:03 AM
Dave421
12
Aug 6, 2003 06:21 PM
asmallsol
Apr 23, 2003 09:59 PM
Jimmy L
Dec 29, 2001 04:22 PM
