findout why my defrost not working.
i figureout the problem why my rear defrost & switch were not working on my db2.fuse all checkout good.test the window lines and plugs got no power but its good.then i pull the fuse box to check "ICU" this sucks!!looking at it.see a bit broken wires on the chip.should i get it repair or buy a new ICU??can computer shop repaired it?
yah,sorry...soon as i get the chances i get some pics.it dont look to bad like it has the brownnes burnt.just a bit of black broken wires.
ICU, isn't that found in hospitals?
just kidding man...
found a guide to fix the ICU for less than 5 bucks, assuming you are good with soldering.
http://www.g2ic.com/forums/showthread.php?t=127170
good luck!
just kidding man...found a guide to fix the ICU for less than 5 bucks, assuming you are good with soldering.
good luck!
alrite.heres the pics is not that clear but u know what it is.check u my page and rate my ride aite..
http://www.cardomain.com/ride/3027812
harwood39
Oct 24, 2004 06:37 PM
