gsr timing off really bad
Old Sep 26, 2009 | 08:00 PM
lilo_goki's Avatar
Default gsr timing off really bad
okay, my gsr was driving good and all, after i did oil change, a week later, it just started to feel weird, when i shoot timing, i can't even seen the 14-18 btdc mark, i have to go under neath the car, and i'll be able to see it, it's a lil below the alternator, i mean how can the car even run when it's retarded this bad, i don't know what can be wrong. i also tested the timing out manually by turning the crank and it is with specs, crank is correct and cams are correct as well, just when i start the car up timing is retarded really bad, the exhaust is choking, i don't know what could be the problem. any help would be greatly appreciate.
Old Sep 26, 2009 | 11:04 PM
lilo_goki's Avatar
Default Re: gsr timing off really bad
bump!! no one ever experience this problem before.
Old Sep 27, 2009 | 01:51 AM
95DC2GS-R's Avatar
Make sure to jump the service connector while trying to reset the timing. IF you do not, the ECU is just going to auto-correct it even though you're physically moving the dizzy.
Old Sep 27, 2009 | 12:37 PM
lilo_goki's Avatar
i'll try to do that to see if it works.
Old Sep 27, 2009 | 02:46 PM
lilo_goki's Avatar
alright, timing is fix now, but my exhaust is still choking, or more like my engine which causes the exhaust to choke, what could be wrong, i did spark plug, spark plug wire, distributor and cap and rotor already,what could be wrong.
dem0nk1d
Jun 27, 2012 12:39 PM
ascarberry
Apr 21, 2011 03:46 PM
killacam661
Jun 28, 2008 09:13 AM
Frederz
60
Apr 20, 2004 11:04 PM
smkngsr
Dec 30, 2003 08:31 PM
