smoking and bogging when cruising
Old Sep 26, 2009 | 07:01 PM
tegsp's Avatar
Default smoking and bogging when cruising
I have a 92 teg with a b20z and only 34xxx on the motor. A couple months ago i was cruising on the highway around 60-70mph and the motor started to bog and lose power. It lasted for a minute then went away. A few weeks later, same thing. I notice a lot of smoke coming out of the exhaust as its happening couldnt really tell if it was white or blue, just a lot. Again, lasted for a couple minutes then went away. Now it just happened again but did it when i was getting around town and it lasted longer. I dont think im burning oil because my oil level remains constant. Any ideas? headgasket?
Old Sep 27, 2009 | 06:55 PM
tegsp's Avatar
Default Re: smoking and bogging when cruising
anyone?
Old Sep 27, 2009 | 06:58 PM
ek-g6's Avatar
Blue smoke= burning oil, White smoke= head gasket. I think your ignition coil might be going out.
Old Sep 28, 2009 | 07:41 AM
tegsp's Avatar
if it were my headgasket, wouldnt it continuously occur? ill look into the ignition coil, thanks.
Old Sep 28, 2009 | 10:39 AM
artevo9's Avatar
My teg bogs too now, but no smokes, I checked the gapping of new spark plugs they're good. I then use sand paper to clean the battery, distributor cap, rotor arm terminals. It doesnt bog anymore after but I am thinking my ditributor cap and rotor arm maybe coil needs to be replaced. Because I just replaced the plugs and wires.
Old Sep 28, 2009 | 07:00 PM
tegsp's Avatar
alright ill give that a try thanks.
Old Sep 29, 2009 | 08:22 AM
teamjdm239's Avatar
sounds to me like a dizzy problem, check out your cap and rotor... .
Emmanlumb
Mar 22, 2016 10:59 AM
hadden
11
Aug 7, 2013 10:57 AM
buddy190
Feb 5, 2009 05:26 PM
egdriver94
12
Aug 20, 2006 07:21 PM
Broken Gearbox
Aug 8, 2003 09:00 AM
