Transmission & Drivetrain Gearboxes, Differentials, Clutches
Need Help B16 Transmission
Old Sep 26, 2009 | 01:55 PM
vietdam89's Avatar
Default Need Help B16 Transmission
hey guys, i know this is my first post on honda-tech but i really need help. i have a 93 del sol with a b16 swap in it. i had to change the outside half of the casing due to the holes for the mount bolts being stripped. when i put the transmission, i started it up to see if it shifted right and everything. here's the thing. when i have the clutch engaged its fine, but when i let off the clutch it just bogs out and dies like it catching on something. its weird and i have no idea what it could be.maybe something with some expertise could possibly help me out?
Old Sep 26, 2009 | 02:57 PM
Aquafina's Avatar
Default Re: Need Help B16 Transmission
You didn't shim the mainshaft and diff. Pull it apart and set the shim clearances.
Old Sep 26, 2009 | 03:34 PM
Mista Bone's Avatar
D Tranny Guru
might need 4 new bearings now.
Heli-coil the old case would have been cheaper.
mahleeh
Dec 23, 2007 04:21 AM
