camshaft install
Old Sep 26, 2009 | 10:28 AM
kornkid21792's Avatar
Default camshaft install
is there a writeup for this for the f series engines i looked but couldnt find anything
Old Sep 26, 2009 | 10:29 AM
NirVTEC's Avatar
Default Re: camshaft install
Probably not.....most don't bother.
Old Sep 26, 2009 | 11:27 AM
street_ride14's Avatar
- Remove valve cover.
- Remove timing-belt tension.
- Remove camshaft holders.
- Remove camshaft(s).
- Remove gear(s) from shaft(s).
- Install gear(s) onto new shaft(s).
- Install in reverse.
- Set valve lash.
- Set timing.
- Tune if camshaft is not OEM.
Old Sep 26, 2009 | 08:39 PM
92civlude's Avatar
Once you get the cam holders and rockers off, put a paint mark on the timing belt and cam gear. You can lift the dist end off the cam to release belt tension and sneak it out without having to touch the tensioner. When you install the cam, just line up the paint mark. and follow STREET RIDE14's instructions
skata89
Dec 19, 2006 09:03 AM
LODOSS
Dec 31, 2003 03:56 AM
acatak
Jan 12, 2003 05:30 PM
oryanh
Jul 6, 2002 01:52 PM
Fooser
Apr 30, 2002 06:54 AM
