ITR/Legend caliper + 23T bracket
Old Sep 26, 2009 | 09:25 AM
Charlie Moua's Avatar
Default ITR/Legend caliper + 23T bracket
Testing waters on my OEM big brake kit:
1992 Legend calipers & 23T bracket for sale = $75
Comes with caliper bolt/pin set.
These are used but have been tested and work perfectly fine on my wife's 2001 CRV.
Price comparison at Autozone:
$7.00 - caliper bolt/pin
$94.99 - $52.99 each with $42.00 core credit ($94.99 no core credit)
$41.00 - each caliper bracket
Total = $202 with core credit ($285 with out core credit)
Again, I'm only selling them for $75.
You'll need new pads & rotors. I have them but rather not sell them because they can be purchased new for less that cost of shipping. LOL
Additional Info:
ITR, Legend, Vigor, CRV, Accord Wagon, V6 accord, H22 prelude = all have 1 7 C L 1 5 V N.
These have a 57mm piston and take larger brake pads than the common Civic, Integra 16CL14VN piston (53mm piston).
Install on 88-00 civic non ex knuckle (will not work with HF knuckles):
1) Cannot keep 9.4" stock civic rotors. So upgrade from 9.4" rotors to 10.4" rotors. (Cannot use 11.1" rotors)
There are 2 ways to install the ITR calipers onto the 10.4 rotor.
A) Place washer in between hub & back side of rotor. Find 2mm flat washer that had 12.5mm(1/2") open diameter to slide over each wheel stud.
or
B) Take the 23T caliper bracket and mill off 2.5mm off the INSIDE of the bracket.
Install on Civic EX, EM1, All Integra (non ITR):
You can keep stock 10.4" rotors OR upgrade to 11.1" redrilled prelude vtec rotors.
Install choices is the same as A/B (above)
In each EF/EG/Integra FAQ form there are links to several of h-tech mebers how have done this. I've done the reasearch already and and spoken to many longtime members on the roadracing forms who have this same setup on their EF/EG/EK/DA/DC with no problems with unevel brake pad fade, unwanted viberation. What has happened is they are able to brake much later/deeper into the apex of turns.
I have many vouches & transactions on honda-tech.
I take paypal or MO.
Best- Charlie Moua
Old Sep 26, 2009 | 04:45 PM
Default Re: ITR/Legend caliper + 23T braket
http://farm4.static.flickr.com/3548/...f240889d_o.jpg
http://farm4.static.flickr.com/3662/...7d56155e_o.jpg
EK dx knuckle with 10.4" gsr rotors & ITR calipers
http://farm4.static.flickr.com/3648/...e2e13852_o.jpg
http://farm4.static.flickr.com/3140/...22ac052a_o.jpg
EF dx knuckle with 11.1" prelude rotors & ITR calipers
http://farm4.static.flickr.com/3025/...138bce97_o.jpg
Old Sep 26, 2009 | 05:29 PM
RyanA's Avatar
PM sent.
Old Sep 26, 2009 | 06:37 PM
Originally Posted by RyanA
PM sent.
just some more info:
Originally Posted by kra95teg
I thought the big brake upgrade was 2 piston calipers?
Well depends on what you call big brake.
All civic (non si/ex) have smallest calipers with 53mm piston
A pair of calipers with bracket is 15lbs.
Civic ex/si & all Integras (non ITR) have larger 57mm piston
A pair of calipers with brackets is 18lbs.
ITR/Legend calipers have 57mm piston but larger pad sweeping area.
A pair of calipers is 28lbs.
NSX/94-95 Legend GS have 2 smaller piston, but share the identical brake pad surface as ITR calipers. I have not weight them yet. but fairly sure they are about the same as reg Legend/ITR calipers.
If you had 1 civic calipers in one hand and ITR calipers in the other... your hand is definatly going to notice the 6.5lb difference.... lol
Also your going to be very suprized how hard your neck is going to snap forward during hard braking. I have a ef with gsr, nothing fancy but I can't count how many times i've easliy locked up by 14' hx rims with falken new falken tires. It happens with not very much effort.
At the track, swapped civics already have the disadvantage of lower displacement. It can be even more stressful at the track when your not able to enter into a corner as fast due to not being able to stop in a short distance like other cars which weigh even more.
For most Integra calipers will do, but for many honda guys at the track ITR calipers with good pads are the min.
Charlie Moua
Old Sep 26, 2009 | 07:13 PM
jesse95's Avatar
bump for very good info/good *** deal!
Old Sep 26, 2009 | 07:23 PM
Thanks!
Anyone who's bought anything from me over the years know I always price items very low compared to the market.
... So don't ask me to sell my NSX calipers... the local h-tech buddies already tried. LOL
Old Sep 27, 2009 | 05:38 AM
RyanA's Avatar
Default Re: ITR/Legend caliper + 23T bracket
These are sold....
Old Oct 8, 2009 | 09:27 PM
Sold 2 pairs so far to RyanA & petwhookie
Thanks for the business I greatly apperciate it.
I have ONLY 1 PAIR left.... but still have 3 set of extra 23T brackets
Charlie Moua
I like my R
Jan 22, 2013 07:21 PM
Charlie Moua
Oct 2, 2009 09:36 PM
jfoster
Suspension & Brakes
Mar 29, 2009 07:58 PM
m735is
Sep 14, 2007 02:27 AM
tgh22a
Jan 23, 2007 06:31 AM
