b16a
Old Sep 26, 2009 | 09:22 AM
mike11's Avatar
Default b16a
I have a crx with a 1st gen b16a. Do any of you guys know if the newer style lma's (lost motion assembilies) the spring type to be exact, will work in my first gen b16a. I'm planning on ordering them for a 00 civic si but need to know for sure if they are going to work.
Old Sep 26, 2009 | 09:26 AM
Bunger's Avatar
Default Re: b16a
As far as I knew, the spring type LMAs came out of H22s? Works with shimming.
Old Sep 26, 2009 | 09:45 AM
mike11's Avatar
Default Re: b16a
Yeah its the cheaper alternative its like $8.00 for the h22 ones and like $22.00 for the b16 ones. But honda made spring type lma's already shimmed from the factory for the b16, but they are for the newer style b16's. That's why I'm not sure if they will work in my 1st gen b16
Old Sep 26, 2009 | 04:31 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: b16a
They will work just fine. If you are in doubt then just measure them when you get them (against the old ones) to see if they need shimming. The only difference between the later version and the earlier versions (on the B16s) is slightly the spring pressure and pad size.
egsleepercivic
Jan 18, 2018 06:49 PM
hoggy
Oct 25, 2003 01:21 PM
Apollojr21
12
Jul 21, 2003 12:26 AM
r7
Jun 12, 2002 05:32 AM
aonick
May 12, 2002 04:17 AM
