intake install question? searched already
Old Aug 28, 2002 | 09:23 AM
hksturbolude's Avatar
Default intake install question? searched already
hey guys, im gonna be installing an injen shorty intake in my cuzins type s on friday and i jus wanted to know what did u guys do with that sensor that was on the old induction around where the battery is? he showed me a pic of his stock engine and there seems to be some sort of sensor on the stock intake it looks like its looped, but its right next to where the battery is...what did u guys do with that? thanks for the help in advance!
Old Aug 28, 2002 | 09:46 AM
TsunamiZC's Avatar
Default Re: intake install question? searched already (hkspoweredlude)
you can wire up your windsheild washer LED's from there.....hehe j/k TTT....some help him out ? mando ...you shoudl know ?
Old Aug 28, 2002 | 10:08 AM
f1nal zeros's Avatar
Here is a picture of my injen intake. The pic is kind of fuzzy but it will show you how it is supposed to look. The little sensor you are asking about goes right into the intake. You can see the sensor that you are talking about at the bottom of the pic. Hope this helps. If you need a step by step instuction let me know. Good Luck.
[Modified by f1nal zeros, 7:14 PM 8/28/2002]
Old Aug 28, 2002 | 10:09 AM
TsunamiZC's Avatar
Default Re: intake install question? searched already (f1nal zeros)
Old Aug 28, 2002 | 12:41 PM
Default Re: intake install question? searched already (tsunami_zc)
thanks for the help ill be sure to ask if i have anymore questions...so it looks like the intake has a place for the sensor to go correct? does that seem right or does it go somewhere else on the car like where would i mount it?...thanks again
Old Aug 28, 2002 | 02:56 PM
Here you go bro, hope this clears things up for you. If you need more help let me know.
Old Aug 28, 2002 | 03:24 PM
AlterEgo's Avatar
What? Did your injen not come with the crack free of charge ? heh heh...
Old Aug 28, 2002 | 08:49 PM
Default Re: intake install question? searched already (AlterEgo)
nah the heat shield was fine...ok i got the whole kit...thanks...ok on the thingy where the sensor goes...does the rubber piece go nipple into the tube or does it stay outside?...also its not very clear about how to install then rubber shock dampners...man the pics of the install suck! hehe...
Old Aug 28, 2002 | 11:05 PM
The rubber part goes completely flush. It should not stick out, push the rubber part and the sensor all the way in. As for the dampers which one's are you talking about?
Old Aug 29, 2002 | 02:34 PM
ok so just to clarify the rubber piece goes nipple into the tube right?...ok the two parts i was talking about are the short and tall vibra-bushings...where do those go? its not very clear in the instructions...thanks a lot zero!
Old Aug 29, 2002 | 02:59 PM
Default Re: intake install question? searched already (hksturbolude)
I will take pictures of my intake today when I get home, but this time I will take pictures of the entire thing up close so it will make it more clearly for you. And no problem bro, I'm always willing to help a fellow member out
And yes, the rubber part goes flush with the intake. It goes all the way in,or as you say "nipple" with the intake. If you need something else just let me know.
Good Luck.
[Modified by f1nal zeros, 12:01 AM 8/30/2002]
Old Aug 29, 2002 | 03:32 PM
thanks a lot zero...yeah the one thing i need clear up is just where those vibra bushings go...
Old Aug 29, 2002 | 07:08 PM
Here are some clearer pictures of the intake. And also I do not have the heat sheild anymore, it broke like 3 weeks after I had it. It sucks but oh well. hehe.. but I have circled in yellow once again. Hope this helps.
And here is a closer shot of the sensor and how it is supposed to look.
And here is a pic of my motor with out the injen heat shield...
Hope this helps bro. If you need help on other installs or anything else just hit me up. Good Luck.
Old Aug 30, 2002 | 09:08 AM
hey zero did ur intake come with the clamps that connect the intake and the throttle body via the sleeve? or do u just use stock ones? cuz i was lookin at it today and i was like wtf they didnt give me any clamps for the tube and throttle body...
Old Aug 30, 2002 | 09:16 AM
TsunamiZC's Avatar
geez mando...clean that engine
Old Aug 30, 2002 | 09:20 AM
You have to use the stock ones that come off your stock intake. Injen could have added them in the package but they got lazy, oh well. Just use the stocks, they fit fine..
Old Aug 30, 2002 | 09:22 AM
Shud UP!!! Go clean your *** homo. heheh.. opps.. sorry Its friday and I'm all wired from the week. ehhe..
I will eventually clean it, but I will wait till th dealership installs the new motor mount, because if I clean it now those bastards will just dirty it once again.. So I will wait and clean it when they are done.
Old Aug 30, 2002 | 10:24 AM
TsunamiZC's Avatar
i hear ya...acura left my engine dirty tooo...like they took a leafblower filled with dirt and sprayed down the motor with it...
Old Aug 31, 2002 | 11:09 AM
zero thanks for all the help...installed the system this morning in bout an hour (ran into a couple probs takin the old **** off...mainly it not wanting to come off hehe) but it came out great...damn that intake is loud!...we hit vtec and BAAAAAAAa it was so loud...pretty good fit...but thanks again for all the help installing...my cuzins very happy now hehe...
Diversion
Jul 21, 2009 11:57 AM
renelovesnike
Apr 26, 2009 10:47 AM
LilKrnThugBoi253
12
Apr 29, 2006 02:31 AM
maxspeedhonda
May 31, 2005 02:17 PM
PhatOptimo
Jul 4, 2002 08:47 AM
