Suspension & Brakes Theory, alignment, spring rates....
Legend GS Dual-Piston Caliper on ITR 4x114??
Old Sep 25, 2009 | 11:48 PM
DBada FM's Avatar
Default Legend GS Dual-Piston Caliper on ITR 4x114??
Im running the 4x114 ITR lug-swap on my Integra and i was wondering if anyone here has ever ran the Legend GS caliper on their ITR 4x114 setup. I need to know what type of modifications i will need to do to the caliper brackets in order to make them fit properly.
Any help would be greatly appreciated, thanks!
Old Sep 27, 2009 | 08:33 AM
DBada FM's Avatar
Default Re: Legend GS Dual-Piston Caliper on ITR 4x114??
Old Sep 28, 2009 | 06:31 PM
roastbeefrichie's Avatar
parts needed
94-95 legend GS 2-pot calipers w/ brackets
92-95 Prelude Vtec 11" rotors (or fastbrakes.com 4X114.3 11" rotor)
pads (ITR, legend GS, NSX, accord wagon, etc)
shims
you'll need to cut the dust shield off to accomodate for the bigger caliper bracket.
you'll need to add shims, where the new bracket will meet with the knuckle in order to clear the rotor
Old Sep 28, 2009 | 10:10 PM
DBada FM's Avatar
Originally Posted by roastbeefrichie
parts needed
shims
will i need to mill any of the bracket part off?
by the wat, what are 'shims'?
Old Sep 29, 2009 | 07:27 AM
flatblack-h22's Avatar
shim = spacing it out with some washers
Old Sep 29, 2009 | 10:09 AM
kulo's Avatar
u can also grind abit of material on the carrier so it doesnt hit the rotor
Old Sep 29, 2009 | 10:31 PM
DBada FM's Avatar
can you please elaborate on this?
Old Oct 2, 2009 | 09:18 PM
Charlie Moua's Avatar
correct me if i'm wrong.... but with the 96-97 ITR 4lug, aren't your rotors only 10.5 vs 11.1 right?
Old Oct 4, 2009 | 09:51 AM
Dogginator's Avatar
Daisy... Daisy...
96 Spec JDM ITRs came with 4x114.3 front rotors that were 262mm in diameter. All rotors had the same diameters as non-ITR Integras. All calipers are shared with non-ITR Integras.
Old Oct 4, 2009 | 02:14 PM
DBada FM's Avatar
one of my main reason of the switch-over is easier access to brake rotors because right now the only Rotors available are the ones from Fastbrakes... having the double piston caliper wouldn't hurt either.
I like my R
Jan 22, 2013 07:21 PM
gunnerman
Suspension & Brakes
Feb 6, 2011 08:58 PM
sumyungguy
33
Mar 30, 2006 06:59 PM
SpoogenJay
Feb 23, 2005 06:37 PM
