Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hard to shift when the trans is hot
Old Sep 25, 2009 | 07:47 PM
SIred91's Avatar
Rainman
Default Hard to shift when the trans is hot
I have a 1st gen B16 with the S1 trans and when I have driven for a while and things
are hot, it starts to get hard to get into gear.... no grind, but an initial clunk ...
Any ideas? This is from a dead stop, or when moving.....and then when its cold,
it works just like new again......
AAARRRRGH!!
Old Sep 25, 2009 | 08:58 PM
Aquafina's Avatar
Default Re: Hard to shift when the trans is hot
What fluid are you using?
Old Sep 26, 2009 | 07:19 PM
SIred91's Avatar
Rainman
Honda MTF and 1/4 syncromesh
Old Sep 26, 2009 | 07:20 PM
SIred91's Avatar
Rainman
It was worse before, when I was just using HMTF....5th was grinding bad.....but now 5th is fine but it is HARD to get it into gear after driving for a while....
Old Sep 26, 2009 | 07:59 PM
Aquafina's Avatar
Change fluid to Supertech 10w-30 dino or Torco MTF.
Old Sep 29, 2009 | 03:02 PM
stevenDAtegra's Avatar
Isn't honda mtf not that great for cable trannies? I don't see why it would differ though since the internals are almost completely the same besides the shift forks, the top bearing etc.
Old Sep 29, 2009 | 03:28 PM
Aquafina's Avatar
Honda MTF isn't good for anything other than daily drivers that never get beat on.
Old Sep 30, 2009 | 09:29 PM
Sobe_Death's Avatar
Maybe for these Front-drive transmissions
I know in the S2000 world if you use anything other than Honda MTF (the new formulation) or Redline MTF most people will get a nasty grind going 1-2 or 4-5
As the local gear guru, what do you think the difference in performance between using the 10w30 and the MTF in these transaxles comes down to? Perhaps just the older design that was meant to work with motor oil in the first place?
Old Oct 1, 2009 | 03:36 AM
Mista Bone's Avatar
D Tranny Guru
MTF is too thin, heat makes it thinner.....might as well run water.
"Well Water!"
Old Oct 1, 2009 | 06:39 AM
Aquafina's Avatar
Bone answered for me.
Old Oct 1, 2009 | 01:34 PM
90sedan's Avatar
I recently went through these exact issues. I first changed out the honda mtf and replaced it with torco mtf. No change. I then pulled the tranmission to check the pressure plate and clutch disc, found nothing wrong, replaced to an upgraded unit anyways, no change. I then replaced my clutch cable with a new oem and problem went away. Apparently after driving for a while the cable would slowly start to stretch and make it very dificult to shift.
If your clutch cable is the original, it's very possible that this is your issue. Also what clutch are you running? Are you running a stock full face clutch with an oem pressure plate or a 6 puck with a heavier pressure plate? If the clutch is an oem type then it should have about a 1/4inch of freeplay in the cable at the tranmission adjuster, but i have found that with a heavier pressure plate adjusting the cable fully tight works best.
Paynes
Honda CR-V & Element
Jan 5, 2018 08:09 AM
LLkoolskillet
Dec 24, 2010 02:40 PM
civiccoupe94
Nov 8, 2007 02:00 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
DOHCRX
20
Jun 26, 2003 11:35 AM
